Heat cycle valve springs?
After swaping stock valve springs to a stiffer spring or a dual spring you should let the engine run to full temp, shut in down and let it cool down to room temp. Then do it again, full temp,cool down. No high rpm's while doing this. I also did these heat cycles when I built my forged moter, for all the new bearings, rings, dual valve springs, ect.
Its like SOMBitch said. Springs are already heat cycled from factory and at higher temps that our engine can get them. they have to have the elasticity to maintain the "spring" to them and they need to be strong enough not to break under normal heat and pressures they are expected to perform in. While it does not hurt it does not help out in any way shape or form. Also like said previously do not beat up on cold rings, that is the one point where they can and will break.
