Good cam for 408ci?
Old Dec 31, 2003 | 02:50 PM
  #41
turbo's Avatar
So how much difference are we talking here on 112lsa and 114lsa? I have a 112lsa right now and I like it. Course its only a C1 and only 346ci.
So many choices lol.
Casey
Old Dec 31, 2003 | 02:59 PM
  #42
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I strongly doubt a 240/240//114 would idle like stock, it will lope but it will have a consistent lope that you get with a 114-116 cam.
The 112 stuff really does not idle as well as 114-116 stuff, it's noticeable for sure.
Old Dec 31, 2003 | 03:49 PM
  #43
monkeyboy's Avatar
what about splitting it down the middle and getting a 113lsa?
Old Dec 31, 2003 | 03:58 PM
  #44
SStroked 410's Avatar
Originally Posted by Chris ARE 360
How big a shot are you spraying?
I think unless you are spraying a 300 shot or bigger I would just spec the cam for NA but have a little wider LSA.
ie: 240/240 114LSA would idle like stock at 900rpm. With the added compression it would make crazy torque too.
Cheers,
Chris
I am starting with a 200 and then later on max out at a 300 shot.
So I think the same in my sig will do pretty good on motor and spray.
Old Dec 31, 2003 | 04:07 PM
  #45
blacksheep's Avatar
The cam in my 408 is a 244/248 618/628 114, its just too bad it doesn't run yet so I could give some more info.
Old Dec 31, 2003 | 04:55 PM
  #46
ApacheDrill's Avatar
I am spraying 150 wet shot and will be dyno tunning it in the spring, it's winter here so no solid runs on the new setup.. The TR 236 is still considered a mild cam with this setup. But is where in need to be for Nitros.. The larger injectors are a must and the 1 7/8 headers as well for this setup. I am hoping to get my hands on a LSX intake before i get it dynoed..I was told because of the cubes.. at the least a LS6 intake has to be used as well.. Sorry to ramble. Just adding that its more then just the cam that makes this setup work.. I am hoping to be laying down some good numbers. I also have a ls6 crank in my block.
Old Dec 31, 2003 | 06:05 PM
  #47
your right,
and you cant go short on the heads either
I have noticed the key with these strokers is to go with a pretty nice size cam, 1 7/8" headers, stage 3 heads, and of course all the bolt ons.
I wonder how much hp gain will be with the LSX vs the LS6 on our stroker motor? I would guess maybe a 5rwhp gain over the LS6.
The LS6 seems to flow very well
I am not sure if the money the LSX is going to be is worth the gain
Old Dec 31, 2003 | 06:10 PM
  #48
I am looking the LSX from a flow aspect, hope the cost comes down a little when it get's out of the street. I have the GTP stage 2 heads. So far i am real happy and cant wait to get some times and numbers..
