Cam Install, need torque specs....
Old Dec 30, 2003 | 12:58 PM
Ferocity02's Avatar
Default Cam Install, need torque specs....
I'm in the middle and need some torque specs before I start to put everything back together.
Engine cover bolts
Cam bolts
Rocker bolts
Spark plugs
Valve cover bolts
Coil rail bolts
Water pump bolts
Thanks
Old Dec 30, 2003 | 01:13 PM
CAT3's Avatar
Restricted User
check out install university or ls1howto.com
All I know is rockers are 22ftlbs, or 24 if you use YTs. The rest I just go by snug +1/4 turn. Never had a problem.
Old Dec 30, 2003 | 01:14 PM
jmX's Avatar
jmX
http://www.ls1howto.com/index.php?article=23
Old Dec 30, 2003 | 01:43 PM
blueWS6's Avatar
here are some torque specs listed in the ls1/ls6 peformance book.
engine front cover bolts: 18
engine rear cover bolts: 18
camshaft retainer bolts: 18 lb/ft
camshaft sensor bolt: 18
camshaft sprocket bolts: 26
valve rocker arm bolts: 22
valve rocker arm cover bolts: 106 inch/lbs
spark plugs (cylinder head new): 15
spark plugs (all subsequent installations): 11
water pump bolts (first pass): 11
water pump bolts (final pass): 22
water pump cover bolts: 11
water pump pulley bolts (first pass): 89 inch/lbs
water pump pulley bolts (final pass): 18
for the rest you can talk to eboggs_jkvl on ls1.com (not sure if he posts on here) but i hope that helps
