will the 224 cam be a noticable difference from...
Old Mar 10, 2010 | 05:41 AM
IWGF's Avatar
Lol 28" tire and a spool w/ high gears (mine aren't quite that high) is pretty streetable.
Old Mar 10, 2010 | 06:41 AM
demarco313's Avatar
I dont really believe in "you will be satisfied for now and then you can go bigger later on." To me why not get it right the 1st time so you wont have to waste money on buying another 1/swapping (labor assuming you dont do your own work) unless you just have money to waste. A nice cam should be at least a 228/228 that you would really love more as a starting cam. Although there is nothing wrong with the 224/224.
Old Mar 10, 2010 | 07:37 AM
Silver408z's Avatar
Originally Posted by orangeapeel
Man, you wont be disappointed. You may want bigger down the road, but it will defintely be a NOTICEABLE improvement for what you were used to.
This says it all.
Old Mar 10, 2010 | 03:56 PM
Nitroused383's Avatar
I'm plenty satisfied with my custom bre 224 cam. Lopes pretty good and now with my ported fast 85mm and underdrive pulley I'm guessing around 430 rwhp with a 224 cam and unported 243 heads.
http://www.youtube.com/watch?v=Ed8s0ovoQDU
Old Mar 11, 2010 | 01:01 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
How is it trying to find a parking spot in a crowded lot w/ that spool? Just moving cars around at the shop was enough for me to just have a spool in a track car that sees some street time. Only for racing though.
Old Mar 12, 2010 | 10:50 AM
Fabian's Avatar
I dropped 6 tenths in my 02 z28 just swapping the stocker for a TR224 112
An idling video
http://www.youtube.com/watch?v=QM8RAThxc7Y
Old Mar 12, 2010 | 10:59 AM
fatmat80's Avatar
I agree, i would go wih atleast a 228 cam..
Old Mar 12, 2010 | 11:54 AM
IWGF's Avatar
Dahaha, that's the worst part of it... It's like parallel parking. Without the parallel.
Old Apr 11, 2010 | 11:42 PM
mtuggle86's Avatar
I wish I would have went bigger last year a nice 228-234 duration cam is what I would have went with instead of my TR224
Old Apr 19, 2010 | 07:05 PM
ThumpnZ28's Avatar
Thumbs down
I'm about to do the 224 swap in my Z/28. Yall wish me luck. So far, I love my car with only the mods in my sig. I will update the numbers when I get it done. Anyone have a prediction as to me numbers??
Old Apr 20, 2010 | 02:58 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I don't like doing predictions, but once again. You will not be dissapointed. There will be a NOTICEABLE difference, and if you cant notice it...You have a VERY bad vac leak somewhere or the car is in limp mode because you broke several sensors and fried the knocks.
So why the thumb down icon on your post? Afraid you will want more too soon?
Old May 13, 2010 | 10:40 AM
  #32
ThumpnZ28's Avatar
Thumbs up
The thumbs down thing was an accident, I guess. I don't remeber doing it. As it turns out, I am super stoked with my 224. It's on a 114, so I missed out on a little more lope, but it runs like a beast compared to before. Thumbs up to COMP for this cam. I will go bigger eventually, but I will need a built trans and probably a 9" before I do heads and more cam. Overall, very satisfied.
Old May 15, 2010 | 01:02 AM
  #33
LSX92Stepside's Avatar
224 should be night/day difference with the supporting mods. great choice.
Old May 15, 2010 | 01:27 AM
  #34
fasteddie94's Avatar
Look at the numbers in my sig. I went from 12.4 to 11.43 by adding the 224r on a 112, mild portjob with stock valves(did mill a little and go thinner gasket), plus the summit stars with skinnies. I don't think cutting a second is anything to laugh at. Sure I could have went bigger, but I'm happy with what I got out of my setup.
Seriously though when do we ever just do it once.....
I know for a fact I could have built the biggest, nastiest, LSX car right out of the box and it still wouldn't be enough. I think most would agree.
Does anyone know the difference between the 224r and the 228r? I think I read on here it was only around 5hp.
Old May 15, 2010 | 06:22 AM
  #35
1fastkingcab's Avatar
did any of you have to flycut with your 224's? I'd like to do a TR224 and a thinner gasket on a project I'm working on.
Old May 15, 2010 | 09:03 AM
  #36
SOMbitch's Avatar
That cam has lots of PTV so you should be fine....
Old May 15, 2010 | 11:34 AM
  #37
ThumpnZ28's Avatar
Cool
I didn't have any issues with ptv clearance and I get the Texas Speed version of the 224. TSP 224/224 has lift at .581, the thunder racing 224/224 has lift at .551. A little more lift, but works really well on stock heads.
Old May 15, 2010 | 05:32 PM
  #38
I have heard that the Thunder Racing TR224 makes better power that alot of other 224*/224* because of Thunders proprietary lobe profile. any truth to this or just vicious rumors?
Old May 15, 2010 | 08:51 PM
  #39
Same here. I was told I could go as big as .230 lift and .600 dur before I'd need to worry about P to V. I don't know about thunders cam making better power, I believe that TSP cam is XER.
When I was looking into mine I was told if you are torn between two cams go with the one that has the faster ramp rate. Sometimes this ends up being the "smaller" cam. It's all about what works in your setup.
Old May 17, 2010 | 01:50 PM
  #40
ThumpnZ28's Avatar
I'm not sure about any of those rumors. My way of thinking is, the more lift I have on my cam,the more fuel and air I can pull in, which in turn, equals more power. Ask around, maybe some other folks will know more about the lobe pofiles.
