Cams for carbs
Old Mar 10, 2010 | 07:58 PM
hornerhotrods's Avatar
Default Cams for carbs
I'm building a carbed lq4 with a victor jr and 1 7/8 long tubes. I have the stock 317 heads with ls6 springs. I'm not sure what cam to run in a carbed setup. Every cam recommendation I get seems to fall on it's face on the top end about 5500 or so. I noticed alot of the cams don't have much or any valve overlap. Maybe that's why it doesn't make hp at high rpms? I was wondering what other people were running or what works with the carbed setup.
Old Mar 10, 2010 | 08:03 PM
xpndbl3's Avatar
i spun my F13 cam to 6800 no problem. Sounds to me like valve float if it stops pulling.
Old Mar 11, 2010 | 06:49 AM
chris-m's Avatar
i have a very mild cam 220/220 111lsa and a demon 750cfm carb. uprated pushrods and valve springs, makes peak power at 6200rpm but will rev to 6500rpm.
Old Mar 11, 2010 | 08:22 AM
butler's Avatar
I am running an ms3 cam 111 lsa engine makes 450 rwhp@6700 rpms with afr 225 heads 750 holley vic jr intake but only 375 torque. Looked on EPS' sight and they say a cam spec'ed out for a stock style efi intake dies on torque on a single plain intake. They have a cam specific for this application.
Old Mar 11, 2010 | 09:59 AM
kinglt-1's Avatar
Comp ThumpR series...
Old Mar 11, 2010 | 10:18 AM
TooLateVTEC's Avatar
If your running a cam meant for fuel injection in a carbed motor that could be a problem.
Old Mar 12, 2010 | 01:13 PM
LSJM1's Avatar
The comp thumper 291 does look somewhat similer to the EPS single plane cam I would like to find a good cam for my LQ9 with a single plane GM intake so far I know they like a tighter LC like 109-110.
Old Mar 12, 2010 | 03:25 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Ive got a MS3 on a 113 in my carb'd TA and it pulls past 7K. And the motor is only a little 346
Old Mar 12, 2010 | 04:04 PM
Somebody wouldn't happen to have the specs on a ms3 cam would they?
Old Mar 12, 2010 | 04:21 PM
237/242 - .603"/.609" 112LSA (standard)
Old Mar 12, 2010 | 04:29 PM
butler's Avatar
That's exactly the cam I am running. afr 225 heads 450rwhp through a 4200 stall turbo 350
Old Mar 12, 2010 | 04:40 PM
^ Thats some good power through a high stalled awfulmatic.
Old Mar 12, 2010 | 04:41 PM
LSJM1's Avatar
I'm sure the MS3 and the like will pull to allmost 7000 on a carb motor but it's the lack of torque with the short runner intake a narrow LC brings in the torque earlier look at the asa cam on a 110 gobs of torque early in the band I know it's a little small for a 6.0
Old Mar 12, 2010 | 04:59 PM
butler's Avatar
6700 rpm peak power on a 111 lsa. Put it on the dyno and with a manual valve body in third it jumped straight up to 5200. May advance it a bit to bring the torque in quicker. Plenty of clearance.
Old Mar 12, 2010 | 05:36 PM
5.3LJimmy's Avatar
You're going to need something with some overlap to get that thing to pull higher. It sounds like you've had a few very small cams spec'ed out. As mentioned above you will also want a tight LSA for that carb setup. 242/248 on a 108 LSA will rip to 7000 RPM's like nobody's business.
Old Mar 12, 2010 | 08:03 PM
LSJM1's Avatar
I think I'm going with the EPS single plane cam .615 .615 236-248 108 LSA. Changing trans to a turbo 400 with a 10" 4000 stall but keeping the 3.42 gear for now.3200 lbs I would love to run anywhere in the 10s NA
Old Mar 12, 2010 | 09:00 PM
butler's Avatar
I love to shift but have found the auto to be more consistent and faster. Besides there is nothing like a decent stall.
Old Mar 12, 2010 | 09:16 PM
xpndbl3's Avatar
I paid Pat G to spec me a cam for my new combo, seems like it's money well spent to me.
Old Mar 12, 2010 | 10:26 PM
well currently its main purpose is to get the truck running and put put around not doing anything radical at this point. i still have to afford cal-tracs, rears, and a cage before i go to stepping on the power a whole lot. It has a glide with a small 2500 stall converter and 4.10 lincoln locked rear. nothing special at this point i just dont want to buy a cam and it turn out to be a total pig.
Old Mar 12, 2010 | 11:13 PM
xpndbl3's Avatar
with a 2500 stall any cam will be a pig....you need to loosen that up by 1500 at least to get into a decent cam
