Started on the red car tonight...
I can't wait to get my wheels back. I think they will look sick being 17x11. I am trying to figure out if I am going to use a 24mm or 30mm spacer for the back. I am sure I am going to have to roll the fender some which shouldn't be that big of deal.
I am looking at the new NT05 tires.
I am looking for two chrome Firehawk wheels so I will have a full set of 17x9's. If I could find a set I would get the NT05R's for the 17x11's since I wouldn't be driving on them all the time.
I still have the racetronix pump/wiring harness, LCA's, brackets and the T/A I am going to order. I am going to so that on the shop on the lift so that stuff will wait.
I will be happy when I get the exhaust on it and can hear everything. Hopefully the idle will calm down after I drive it.
"So far" it sounds good. It's not backing firing out of the intake or exhaust so that's a good thing.
Drive shaft is in, well it's in after I tried to fill the tranny and dumped about two quarts of Mobil ATF fluid on the floor. Now it's full.
Took all the brake parts off. Cleaned and sandblasted the calipers and brackets.
Two coats of high temp primer. Tomorrow I will prime the rotor hats. The replacement caliper I got from Car Quest looks like someone took a grinder to it to fit a set of pro stars. I am sending it back and hopefully the next one will look like factory.
After reading a thread in the suspension section I am going to have to break down any buy a T/A so I can have my exhaust made once.
Still no word from weldcraft on the status of my rims. I am still trying to decide if I should go with the NT05 or the drag radial. My poor 7.5 doesn't stand a chance.
The car is on the ground now and I am going to take it for a quick drive later. Here is a better idle video.
http://www.youtube.com/watch?v=ABstKJpv_NU
It hunts idle really bad, never dies but it wants to. Part throttle and anything under 2 grand it bucks really bad. After you get a certain point it smooths out. It feels like it has a miss in it but no SES light.
After I get exhaust on it I will try again.
For what it's worth, I had an exhaust leak about the size of a pencil eraser that was about 18" from my O2 sensor and my car had a ton of drivability problems. After getting that leak fixed, it was a night and day difference, no other changes.
I got the UMI adjustable long T/A with the relocation bracket from Sam. This thing looks serious.
I dropped the rearend and fuel tank tonight.
Installed the racetronix pump. The fuel sock on the outside of the module is filthy. There seems to be all sorts of **** in the tank. Where I picked this up I don't know. I will replace the sock and filter and try to get the crap out of the tank.
After that I have the T/A, roto joint LCA's and relocation brackets to install. Then off the exhaust shop.
I decided on the new Nitto NT05 R tires today an ordered them. We will see how that goes. If they hook I am sure I will blow up my rear. I will have to take it easy on the power shifts.
The racetronix stuff is top notch. I have used it in the past and would not use anything else.
I installed the T/A, relocation mount, LCA and brackets and the fuel system upgrades.
The UPS man showed up with my NT05 R's today. Oh they are sexy.
I am waiting on the rims to get back from WeldCraft.
I am going to have to wait till next week to get it to the exhaust shop. The guy I work for is on his way to the Mopar Nationals with that Super Bee and a Daytona so I won't be able to use the trailer till then.
In some spare time I hooked up the nitrous solenoids/jets/purge. I am not looking forward to the wiring, but that's a ways off. I won't spray it until it gets dyno tuned.
