looking for the best cam!!!!!!
Old Mar 26, 2010 | 05:48 PM
garygnu's Avatar
go to Taxes Speed Performance webstore .they offered some CNC #241 heads with any TSP cam for $1100.check out their cam kits.$590 for cam/springs/push rods.if you can not find a used LS6 intake SDPC sells them for $490 new.
Old Mar 26, 2010 | 08:40 PM
1969mach1's Avatar
ivebeeninoklahomabeforeandyesitsucksthestreets
areverybadnotsurehowwellstreetracingisupthere
youmayneedtostartwithsomesuspensionupgradesfirst
hahaha! just messing with you!
Old Mar 27, 2010 | 05:29 AM
Soul TKR's Avatar
this thread is funny
Old Mar 27, 2010 | 01:13 PM
hammertime's Avatar
Originally Posted by victor111262
oh and probably taking the heads to get clean putting new springs lifters rocker arms and push rods, putting gear drive set up on it 2 and oh and cutting the heads please post wa other things i should add oh and yes the cam is getting done now. thanks
What is the mileage on this engine? Lifters are good insurance on a high mileage motor, especally where you might end up with a cam over .600 lift at the valve. The stock rockers are as strong as you will find, and lighter than any roller rocker. Save the stockers and reuse them, or rebuild them with one of the trunion upgrades like Harland Sharp or Comp Cams offers.
I hope you aren't set on a gear drive. A quick search shows that noise is a real issue, unless you plan on running a carb and distributor, the knock sensors would not agree with your plans:
Gear drive for LS1?
gear drive?
Gear Drive?????
But if you just have to have one...
Anyone using a gear drive instead of a timing chain?
Lastly, wait to select your springs and pushrods until after you have the heads cleaned (resurfaced?), have choosen your head gaskets and have your cam. All of these factors effect the proper length on the pushrods. Since LS engines do not have adjustable valvetrain, the pushrod length is critical to the proper lifter preload.
Old Mar 30, 2010 | 03:49 PM
kawijames's Avatar
Wow. That kinda gave me a headache trying to decipher it all. All I can contribute is max power means nothing if you hit it after the race is over. Under the curve is where it's at.
Old Mar 30, 2010 | 03:56 PM
KevinR's Avatar
LMFAO.. Oh man. Thanks, I really needed this today. I was having a shitty day.
