looking for the best cam!!!!!!
Old Mar 21, 2010 | 01:28 AM
victor111262's Avatar
Default looking for the best cam!!!!!!
hi like the tile says im trying to get the best one with the lest noise possible and the most power, on a good power band i got a 6.0 lq 241 heads and ls6 intake.
Old Mar 21, 2010 | 08:55 AM
hammertime's Avatar
Research EPS (Engine Power Systems) a sponsor here. They have recently released a new series of lobes that are easier on the valvetrain. I am sure there are others out there too that aren't as agressive (Comp XE, Crane) but these seem to have been producing good results.
As far as most power, good power band, for anyone to give you decent advice, they will need to know more about your application.
Driver/weekend warrior/track car?
Stick/auto/gears/stall?
Supporting mods?
Old Mar 21, 2010 | 09:00 AM
lemons12's Avatar
There is no "best" cam, period. 241s and an ls6 intake are going to limit you for sure.
There are cams out there to better suit your setup than others, but never a "best" cam.
More info needed.
Old Mar 22, 2010 | 03:51 AM
well i was using 241 cos they toll me they would do some high comp. and thats wa i need it, but if i would get more of 6.0 heads ill buy some but whats wrong with the intake thoought it was better than the one of the truck.
info would im taking my lq9 block to get pistons and stuff put in tuesday and every thing is going in a 2001 camaro z28 m6 i got 4.10 in the stock rear end i still have the whole ls1 thats where i was going to get some parts of oh and i also bought ls7 lifters and jumpers and injectors.
Old Mar 22, 2010 | 07:32 AM
hammertime's Avatar
Supporting mods?
Is this a drag car? Are you running Long Tube headers and an ORY or duals?
Old Mar 22, 2010 | 03:55 PM
im keeping ac so guess not really going to be a DD im trying to keep the engine bay looking as stock as possible so im just going to run duals with out headers just taking cats off not a drag car really mostly for street racing.
Old Mar 22, 2010 | 04:32 PM
westtexasbuff's Avatar
Get a torquer V2.
1969mach1's Avatar
What? I don’t know what your saying. I don’t know when one sentence ends and the other begins.
So keeping the a/c makes it a non daily driver?
I think I saw “street race" in there, is it going to be strickly for racing? What are your goals for the car?
Old Mar 22, 2010 | 04:37 PM
1969mach1's Avatar
From what I can decipher, it looks like you may what the Thunder Racing CheaTR set up.
http://www.thunderracing.com/catalog...vid=3&pcid=289
Old Mar 22, 2010 | 04:50 PM
no wa i meant is that im keeping the ac
im only mostly racing on the street
i dont care about DD
Old Mar 22, 2010 | 10:52 PM
redws618's Avatar
Are you high? Lol are you okay buddy?
Old Mar 23, 2010 | 04:12 AM
no im not high and yes im ok thanks, i live in okc so is hot *** hell in the summer so im keeping ac, and if you mean cos the street racing i dont care or about daily driving dont care about it.
Old Mar 23, 2010 | 05:33 PM
hey ijust run into a problem i need a crank and connecting rods for stock 6.0
or a good stroker kit trying to keep it in budget cos im trying to use nitrogen
thanks
Old Mar 23, 2010 | 06:03 PM
eamador11's Avatar
bra, get my cam!
Old Mar 23, 2010 | 06:04 PM
eamador11's Avatar
Originally Posted by lemons12
There is no "best" cam, period..
I have the best cam
Old Mar 23, 2010 | 06:23 PM
wa i meant for best cam was for my set up
Old Mar 23, 2010 | 08:20 PM
hammertime's Avatar
Lucky for you, 78% of our atmosphere is nitrogen - all cams works very well with it...
Thankfully, after several requests, we have a halfway decent idea of what your setup is...sorry if the sarcasm makes me sound like a like a dick, but articulating exactly what you want, and giving everyone the details needed instead of having them dig for information goes a long way to getting help in the forum.
As far as street racing is concerned, you might be racing from a big roll, you might be going from a dig, etc. The best you can hope for is a combination that makes the best power across the board. Avoid the temptation to run a large by huge cam and stick with something in the low 230's duration. Nitrous Oxide is only a consideration for cam selection if you are regularly running big shots (200+) and less of a consideration on a street car. Getting a good flowing set of heads and tailoring the valve events and compression for your build will go a long way to building a solid street racer.
Good luck with your build!
Old Mar 24, 2010 | 12:17 AM
well im not worring about the cam now is trying to find some connecting rods in oklahoma fuken sucks
Old Mar 26, 2010 | 05:19 PM
well change on plans just bought an lq4 long block so now i got the 317 heads and the truck intake wich im thinking of geting rid of and purring the ls6, just order the frame connectors and the short shifter
Old Mar 26, 2010 | 05:22 PM
oh and probably taking the heads to get clean putting new springs lifters rocker arms and push rods, putting gear drive set up on it 2 and oh and cutting the heads please post wa other things i should add oh and yes the cam is getting done now. thanks
