my porting heads
Old Mar 21, 2010 | 02:27 PM
jaber911's Avatar
Default my porting heads
what do thinks guys about my hand port ?
Attached Thumbnails my porting heads-20100321051.jpg   my porting heads-20100321053.jpg   my porting heads-20100321055.jpg   my porting heads-20100321057.jpg   my porting heads-20100321059.jpg
my porting heads-20100321052.jpg   my porting heads-20100321054.jpg   my porting heads-20100321056.jpg   my porting heads-20100321058.jpg   my porting heads-20100321060.jpg
Old Mar 22, 2010 | 12:25 AM
jaber911's Avatar
any one ??
Old Mar 22, 2010 | 12:29 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
What did the flow bench think of it? Looks pretty well blended.
Old Mar 22, 2010 | 01:01 AM
jaber911's Avatar
This heads still need a little polish
I do not have equipment to examine the flow rate
Is there another way to check the flow of these heads ?
for the intake runner near 211 -212 cc This is after collecting
porting dust
thanks orangeapeel
Old Mar 22, 2010 | 02:39 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Now polish the exhaust ports! I would take them to a machine shop now and have them tanked and milled. It will showcase your porting.
Old Mar 22, 2010 | 03:32 AM
Mikeshotrodshop's Avatar
A flow bench is the only way to tell. If the table vibrates, you are definetely turbulant :0)
Old Mar 22, 2010 | 06:38 AM
garygnu's Avatar
I feel you could remove a little more from the right side of the guild.don't polish them.
Old Mar 22, 2010 | 10:23 AM
Paint_It_Black's Avatar
It's going to stall around .450 and not gain much after that. I can tell from just looking at it that the FPS over the short side is going to be WAY too fast and separate once any lift is achieved. Looks pretty though.
Old Mar 22, 2010 | 10:27 AM
eatlead's Avatar
flow bench is the only way to know if you did good or bad
Old Mar 22, 2010 | 10:30 AM
and sometimes that won't even tell you. You can make changes that will gain 5cfm and lose 20hp.
