X1 cam or G5X3?
Hey everyone! I have a question that won't stop bothering me until I ask it, even though it may sound a little stupid. I know it will be a long time until I have enough money for a H/C setup, but I really have been contemplating whether to get an MTI X1 cam or a G5X3 cam. I would really like to know which one would make better power and net better 1/4 times, and still be very reliable. Even though I drive my Trans Am every day as a daily driver, it doesn't bother me too much to have a gas guzzling monster(and if worse comes to worse, I always have my daily driver CRX Si with only about 35,000 miles on the new engine). I know I will need tuning with either one, especially with my A4. I have also been thinking about getting MTI's stage 2 heads, but I've also been hearing alot about TEA's heads. I plan to run a Yank(definitely a Yank) 3600-4000(most likely a 3800) stall converter, and I might decide on a 125 wet shot of nitrous in the future(but not likely). Any help would be greatly appreciated! what he said, if you go with the x3 might want a 4k+ stall.
anyway..just my opinion...things to take into consideration..justin l
99SS M6
Secondly i would recommend the X1. I trap 127mph in an A4 and the car almost drives like a stocker. A c2 would be smoother and make almost the same power... but it WILL be less.
You choice of the Yank verter around 4200 and the X1 is a match made in heaven. A TP4200 is not the best street verter out there but it can be done if you do not mind the slippin' around town. TIP: the louder the exhaust the more it will bother you. A quiet exhaust (or one that is not blaring) will help on the "drivability" sensation.
Heads? Man, the MTI ones are the ticket and a perfect compliment for that cam. Stage 2-X1 cam- and a killer effecient Yank TP4200. Can you say mid 10's if the rest of the combo if well thought out?
I thought you could.
Good luck buddy.BTW, gas mileage is not that bad on the freeway. Not that bad at all.
and when you yank everything out ur car and get the thing light wheels up launches are around the corner!!
SDB
Tires amigo. Tires are the answer. If you make more power than your tires will hold you will spin.(period)
That is the only aswer i can give you. Tires.
If you do not want to spin you must use softer and softer tires. As you add more power, you will over come the tires and then you will realize you need more tire.
For mid 12's and high 11's you can get by with some Nittos, from 11.9 to about 11.4 you can maybe get by with some E.T. streets. But from 11.4 on down, on a prettymuch stock suspensioned F-body you will need some form of slick.
Now with that all said, you "could" go with a soft 1.6 STr verter' like the Super Yanks, talk to mike @ Yank. (www.converter.cc) Tell him that you would like to have a converter that will not blow the tires away but will pull like gang busters in the mid range and top end.
If you are mostly racing from a roll this becomes less and less important, but if you roll from the dead dog digs (stopped) then you will need tires. Big sticky wide *** tires that suck rocks in the rain.
I would recommend the Hoosiers over the Mickey T's. Even though i have had phenominal luck with the MT's the Hoosiers are getting all the rave reviews.
Note, once you get in the mid 11 sec range the E.T. streets are not very consistent.
(read: SPIN)
Good luck and i hope some of this info helps you out.
