cam swap done... BIG PROBLEMS
Old May 12, 2010 | 07:00 AM
  #161
Pro_built7's Avatar
****... nevermind lol just read that you got 'er goin.
congrats!
Old May 13, 2010 | 05:18 PM
  #162
prjctSILVERKNIGHTy2k's Avatar
well i did have a second tune done before it died. I need to get a wideband to finish tuning it. My injectors were only running at 63%.
Old May 14, 2010 | 12:08 AM
  #163
and that was rich as all hell
Old May 14, 2010 | 08:05 AM
  #164
01ssreda4's Avatar
9 pages of fail, and for the record my coils dont swap sides bc the wiring plugs do not fit unless they are on the correct side
Old May 14, 2010 | 09:02 AM
  #165
rich5368's Avatar
I must say that this was an enjoyable read. Bored out of my mind at work and you guys helped me burn half an hour. I even laughed a few times. Merv good luck to ya. I did the Died 3 times before I crosstrained to FE.
Old May 15, 2010 | 03:08 PM
  #166
good news. played with it yesterday and i got it running. we played with my ve table and we nocked out all my random misfire. the car starts right up and runs now but i only habe a 30 second window where it has power then it just sputters when you give it gas. My fuel to air ratio is rediculously off
Old May 15, 2010 | 11:22 PM
  #167
Duffster's Avatar
What are you using to tune it and what instructions are you following?
Old May 16, 2010 | 07:49 AM
  #168
Daryn's Avatar
Formerly darynC-10/23/10
glad to hear its back right........ what was your compression in the cylinders?
i hope you put a fresh oil pick up o-ring since you put youre new timing chain on
Old May 17, 2010 | 01:38 PM
  #169
i have a buddy that tunes with hp tuners. He tunes me whenever hes around for free i just paid for the credits. And Yes i did throw new o rings in.
Old May 17, 2010 | 03:28 PM
  #170
crainholio's Avatar
Um...how many o-rings did you put on your oil pump exactly?
Old May 24, 2010 | 11:55 AM
  #171
I Love toys's Avatar
gettin ready to do a cam swap myself, this thread is scary! lol does everyone rely on the lifter retainer thingys that are in the motor to reliably hold the lifters up??? haven't started it in about a month so i'm thinkin they should be pretty dry. i just don't want to have to pull the heads if they don't always work. seen the magnet pen trick on a how to page and the tool is to expensive for a 1 time deal. so they should be fine or do the magnet trick for insurance?
Old May 24, 2010 | 03:01 PM
  #172
SINISTER-TA's Avatar
Man...reading this thread would make you think doing a cam swap is near impossible. And what is with all the "don't get a double roller timing chain" comments? I had no issues installing my Comp double roller with my cam swap. It definatley was not a big hassle when installing it and works just fine. I would much rather use it than an LS2 stocker. Maybe it's just me...but there seems to be some bad info in this thread.
Old May 24, 2010 | 03:24 PM
  #173
Paint_It_Black's Avatar
Because people run into oil pump clearance issues a lot with double rollers. There really is no reason for them when the LS2 chain is doing fine in many 1000+ hp builds.
Old May 24, 2010 | 03:38 PM
  #174
ya i think the mellings have a clearence problem with the dbbl chains but i believe the SLP pumps will fit fine.
Old Jun 9, 2010 | 01:34 PM
  #175
434strokergt45r's Avatar
Banned Scammer
the coils can go on either side
Old Jun 9, 2010 | 02:17 PM
  #176
kb274868123's Avatar
subscribing. Doing a cam install next week.
Old Jun 9, 2010 | 02:32 PM
  #177
ThunderstuckN20's Avatar
sorry but you definitely need to pull that front of that motor back apart before you really destroy some **** dont crank it anymore
Old Jun 10, 2010 | 05:59 AM
  #178
read a little more of the thread man ^^^^^
Old Jun 10, 2010 | 07:18 AM
  #179
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
He's just post whoring. We see it all the time.
Old Jun 10, 2010 | 05:53 PM
  #180
05blackgto's Avatar
Originally Posted by Davo346
correct tool? a 3/8 ratchet to pry with thats pretty dumb if you ask me ,why would you possibly bend your ratchet instead of using something that it wouldnt matter if bent it or not
like i said some people dont need wrenches ,like some people dont need guns,they might shoot their foot off or they might install a cam wrong or use a 3/8 ratchet to pry with, im sorry anyway if your talking about the bolt on the tensioner its not a 13mm i believe its a 15mm ,dont wanna **** nobody off but you say correct tool thats just funny to me
dude i think its time for you to shut up!!!!! go take your tire iron and beat youself in the head!!!!! yes a ratcher is way better AKA right tool for the job. Maybe, if you didnt buy your tools from kmart they wouldn't bend!!!!
