cam swap done... BIG PROBLEMS
Old Mar 31, 2010 | 08:24 PM
  #101
XtraCajunSS's Avatar
Wow guys there is so much mis-information in this thread...
FWIW, the coilpacks and brackets are completely interchangeable from side to side. This is true from '97 to present. The harnesses are actually numbered for both sides...
As long as the cam and crank sprockets are dot to dot at final assembly, you are good.
A simple cranking compression test will most likely tell the tale with the least amount of effort.
I may have missed a few points but I hope this helps clear up at least a few things.
Shane
Old Mar 31, 2010 | 09:52 PM
  #102
sidewayz28's Avatar
Originally Posted by Davo346
apparently you dont know what i mean
c'mon now, get a sense of humor dude..
Old Mar 31, 2010 | 10:37 PM
  #103
tillery's Avatar
Wow. Lot of machoism at stake on this one-lol. Its cool Merv. I had only 2 deployments-each 2 yrs long-I'm ARMY AVIATION tho. Now back to our regular scheduled drama. So he may have messed up? Any close wiling to lend a hand to help find that gremlin?
Old Apr 1, 2010 | 12:31 AM
  #104
the_merv's Avatar
Veteran: Air Force
I knew what you meant..I was trying to make a funny..
A while ago one of the guys I worked with had to change his alternator..he took it out with a Tire Iron and a pair of plyers..I'm still trying to figure that one out..lol
Old Apr 1, 2010 | 07:32 AM
  #105
tillery's Avatar
Where there a will-There's a way. But I would like to have seen that. Seen people install rotor blades upside down.
Old Apr 1, 2010 | 08:08 AM
  #106
Davo346's Avatar
i know on my fox body i had i had to put the belt on the alternator then pry with a tire iron to move the alternator in place to put the bolt in ,and the pliers well he probaly didnt have a wrench and in most cases you need something like a tire iron to pry the belt tensioner to put the belt on
Old Apr 1, 2010 | 09:23 AM
  #107
the_merv's Avatar
Veteran: Air Force
You didn't have a Tensioner on the Fox Body?
You know as well as I do we don't need to start a thread of messed up stuff in the Military..we would be here all day talkin about that..lol
Old Apr 1, 2010 | 09:48 AM
  #108
Davo346's Avatar
yes i did but the belt was so tight of a fit i had to pry on the alternator also.
anyway why would you wonder why somebody would have a tire iron or anything such as that to change the alternator,makes me wonder about you.you got to relieve the tensioner with something.
Old Apr 1, 2010 | 11:07 AM
  #109
the_merv's Avatar
Veteran: Air Force
That's when you get a Belt about 2" longer..
anyway why would you wonder why somebody would have a tire iron or anything such as that to change the alternator, makes me wonder about you. you got to relieve the tensioner with something.
LOL..Ya I use my 3/8 Ratchet and a 13mm Socket on the Tensioner Pulley Bolt..that would be one of the CORRECT tools for the LS Engine.
At this point are you still wonderin why I don't use a Tire Iron to move the Tensioner?
Old Apr 1, 2010 | 11:49 AM
  #110
Davo346's Avatar
Talking
2 inches will be too long anyway i just had to pry it about a quarter inch to get the bolt in dumba.....
correct tool? a 3/8 ratchet to pry with thats pretty dumb if you ask me ,why would you possibly bend your ratchet instead of using something that it wouldnt matter if bent it or not
like i said some people dont need wrenches ,like some people dont need guns,they might shoot their foot off or they might install a cam wrong or use a 3/8 ratchet to pry with, im sorry anyway if your talking about the bolt on the tensioner its not a 13mm i believe its a 15mm ,dont wanna **** nobody off but you say correct tool thats just funny to me
Old Apr 1, 2010 | 01:11 PM
  #111
Texas_WS6's Avatar
Just because they might shoot their foot off does not mean they do not need guns! Guns and feet have nothing to do with each other or with this forum or this thread. If you want to talk politics go to a different forum. This is not the place for politics.
Were is the moderator?
Old Apr 1, 2010 | 01:19 PM
  #112
Texas_WS6's Avatar
Just making fun, we don't need no moderator here man.
Don't pay any attention to me, I am just bored on my lunch brake.
Old Apr 1, 2010 | 01:53 PM
  #113
Davo346's Avatar
i hear ya ,not trying to be political at all ,just a saying
Old Apr 1, 2010 | 01:58 PM
  #114
Davo346's Avatar
it was a joke in the first place ,now who needs the sense of humor dude??? it just sounded like he was being a dumba.. im sorry if i took that wrong
Old Apr 1, 2010 | 02:06 PM
  #115
the_merv's Avatar
Veteran: Air Force
Obviously you aren't familiar with the LS1.
Let me educate you..
With a little muscle it moves very easily with a 3/8 Ratchet..WITHOUT bending it.
And I'm pretty sure it's a 13mm..I would check but it's 7,000 miles away at the moment..anyone want to help out?
Simple things amuse simple minds..
Old Apr 1, 2010 | 02:15 PM
  #116
Trevor.j's Avatar
should be a 15mm inless its aftermarket one..
Old Apr 1, 2010 | 02:21 PM
  #117
the_merv's Avatar
Veteran: Air Force
I'm bored in the desert..
Ok..I can settle for that..
Old Apr 1, 2010 | 02:27 PM
  #118
Davo346's Avatar
educate me lol . its a 15mm ,you took all that time to put a picture on here and didnt even check the size .anyway im familar with the ls engine ,and another thing i corrected myself on the prying part ,i was just saying on some tensioners that are longer ,you can pry the tensioner.AND I AM SURE IT IS A 15mm.And my simple *** is laughing again.YOU REALLY DONT NEED TO TELL PEOPLE THINGS IF YOU ARE NOT REALLY SURE ABOUT IT,THATS CALLED BULLSHIT
Old Apr 1, 2010 | 02:39 PM
  #119
the_merv's Avatar
Veteran: Air Force
educate me lol . its a 15mm ,you took all that time to take a picture and didnt even check the size.
Here..you fail at reading so I will help..
I even put it in big 'ole ****** barney style Army-proof letters for you.
Next will be a photo of a Map with my location, just incase this doesn't work.
**** this thread wins..
Old Apr 1, 2010 | 02:41 PM
  #120
the_merv's Avatar
Veteran: Air Force
I think I just pulled your card and stamped it like 3 times there bud..
