AI CNC TFS 208cc LS1 heads
i think the AI TFS 208cc LS1 heads will perform better than my 215's because of better port design and usualy when any 2 different cathedral heads (or any kind of 2 heads of the same type) make the same rwhp the one with smaller runner usualy i'm saying usualy will make more torque due to higher port velocity.
There is a lot more than port velocity in the equation to making torque. Smaller does not necessarily mean better. Personally I would stick with the tried and true 215's.....
And what do you consider better about the port design other than a smaller runner on the AI's???
[/B]
consider 2 heads the GM LS7 255cc heads and the TFS 235cc heads. the GM LS7 heads when ported will go to 265cc maybe even more. and the TFS 235cc when touched up will reach 237cc-239cc. now both heads will make close rwhp to each other but the TFS 235cc will definitely will make more torque. that is what poeple are seeing when using these 2 heads.
what is the minimum cross sectional area? what is the maximum cross sectional area? where are they located? What is the average air velocity? any unusual local velocities? what size valve? how many cfm per square inch of curtain area? which head promotes better swirl?
If engines operated at a constant 28" of water depression, life would be a lot easier. Unfortunately cfm and runner size sell heads. Well, except to the people who really want to go fast..
No, runner size is not a great indicator of torque.
what is your car? and your mods?
#33
Abdullah
It sounds like your mind is made up so GREAT luck to you and I hope your setup performs like you want it too... AI does turn out some impressive stuff and I am sure it will haul ***. Let us know your results !!!
I just wanted to make the point that the smallest runner does not always make the best torque. PIB just states it much more eloquently and technical than I.....
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#34
Abdullah
I just wanted to make the point that the smallest runner does not always make the best torque. PIB just states it much more eloquently and technical than I.....![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
you are correct smaller runner doesn't always mean more torque or more hp that what AI told me, they AI told me it is the port design that makes more torque and hp. but from what i saw from different heads through the years usualy i'm saying usualy smaller runner will make more torque and some times more hp (if i'm wrong then at least maybe for the street heads not for big race heads).
