ls6 stage 2 heads.
whats the biggest custom cam specs i can do with a 113 or 114 lsa without having to flycut the pistons?
tsp told me the tsunomi is will fit (235/240 .654 .609) but my custom 236/240 .612 .609 or even the 236/238 .602 .605 wouldnt fit dont really remember why they said it wouldnt fit, they told me to try and get me to buy the tsunomi or torquer 3...both huge in lift. most their cams have one thing i want but not the other or vice versa.
main question, which custom cam spec will complement the heads best while keeping semi streetable( alot of people saying they love their ms3 as a dd).....seems a little sluggesh on take off, so something a tade smaller is what i`d consider perfectly streetable.
current set up. custom headers, intake, 2.5 x pipe exhaust.
future mods, be adding some kind of IM(fast) and TB and pully. maybe nos
haha ps, i was just trying to know what was the biggest i COULD go so i knew, Not that i was going to do so. just need to know the limit without flycutting thanks
Are they milled?, valve size?.
If you do not have this info, your best bet is to put the cam you want in; measure PTV clearance and then decide on flycutting or not.
http://www.texas-speed.com/shop/item...d=134&catid=40
thank you pre-z, didnt think about putting the chart up.
but anyways, yes that is what i am asking, what would be the best cam for the heads, on the mild/semi big side.
(brian, i agree with you on what you saying, i just rather want at least a 234 236, then a baby 224/224 cam, i dont want to loose power after 5.5k-6.)
BTW you car sounds like a best in a half, specailly for that small cam, 112lsa?
from the specs i`ve given, example: 236/238 .602 .605 114lsa, would the stage 2, 5.3 heads be a better choice?
i`ve looked up alot of dyno sheets and people are only making roughly 410-420whp with ls6 heads and v2, with all bolt ons, im hoping to have around 430whp, but w/o the ported TB and fast IM. when all is said and done, with pulley,IM,TB i`m hoping on roughly a good 480rwhp....
but anyways, back to what was asked above please.... thank you
https://ls1tech.com/forums/texas-mem...step-step.html
Cam recommendation: 1986 Monte Carlo with LQ4 6.0L short block, 64cc PRC stage 2.5 LS6 heads, .041” gasket, Victor Jr. intake with carb, Auto with 3200 stall, 3.73 gear, 1 3/4” long tube headers, 6600 rpm shift points, 7000 rev limiter.
230/238 .600”/.604” 111LSA +4 advance
but am i just not getting something, on many peoples combos ive looked up, when they are running a ms3 cam, it can fit with the 5.3 heads(w/o flycutting)and not the ls6 stage 2.5 heads, but they have the same specs, 2.02" 1.575.... besides flow numbers, the ls6 has better flow number... only reason im being so...****.. is cause for me, being in college and only working part time, even a minor $2000 is a big purchuse for me to spend. just want to make sure im satisfied the first time.
