what "Re-Build" actuall means.
#46
Moderator
http://www.youtube.com/watch?v=MAfdq...eature=channel
http://www.youtube.com/watch?v=HQfh6...eature=channel
#48
that is an awesome vid. I have another friend at my unit, he has a '99 T/A. He told me that the camaros ls1 engine could be removed from the top but T/A's had to be dropped from the bottom only? sounds alil weird to me but is it true? I had just brung up the subject of a cam swap. I thought u could just remove the radiator to make space to do the swap, is a engine drop neccessary? wth...
#50
his T/A is badass but I know he's a cocky arrigant ******...My advice/opnion wouldn't matter to him. one of those guys you can't them ****...
Although I took my buddy who has an Evo X for a ride and was highly impressed, I think he might be reconsidering those 4cyl's and converting him to bigger blocks...his evo 10 is nice and all but it's not even close to being worth $30K
#51
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
With the $$$ that you're buddy is spending on a rebuilt...he sould just buy a short block from a sponser...and slap on the heads if their in good condition, it will be around the same amount spent.
#52
^^^ who is a decent priced sponser for blocks? or crate's? If my compression test looks bad enough, I may just go with a new block cause I'm already missing an ear off the bottom of the block for one of the starter supports. ( and since LS1 are aluminum, hard to find that welder, plus I would still need the ear lol )...had a shop bolt a bracket up for me, Good, decent Temp fix.
#54
I did my cam swap without dropping my motor. All I did was remove the radiator (and all parts blocking that). It was a fairly easy process, although I had removed the entire top half of my engine (other then the heads), But that's because I was also doing an intake manifold swap. Shouldn't be hard to get the cam out and in.
#55
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
but yeah thats what I was thinking, remove the radiator, did u make a mess? lol
#57
-Chelsea
