Can I use Comp 918's in machined spring pockets?
Yes you can still use the 918's. You need to run the stock spring seat, like you would from the factory anyway, and that's it. The spring seat locates it from the inside of the spring. Doesn't matter how much room there is on the outside of the spring.
Chris
Chris
Originally Posted by 1fastWS6
I have heads machined for the larger dual springs (987, 977, etc). Can I run the smaller dia. 918 springs in this case? Wondering if the spring will 'walk' around on the seat?
