Not completely satisfied
OP...Full tune would be the best. My car just street tuned made 403/355. Almost 30 lbs torque difference just by throwing it on the dyno and making three runs. Adjusted my AFR, and added timing.
Larry
You never want to go over 80% of duty cycle on your injectors. that doesn't mean go out and get the biggest injectors either, your stock computer can't read over 60lbs injectors anyways. match injectors to hp needs you will probably be very well off with 36-42 lbs injectors. Once the injectors hit 100% of duty cycle they loose the ability to control fuel flow and can throw the best tune out of whack.
I would also like to know more info on the heads(milled, ported, what valves, etc...?). I'm inclined to say your missing power is due to the tune, but also agree that some fuel upgrades would be in your best interest. It is possible to run your setup on the stock fuel system but it will be maxed out and far from optimal.
Agreed. I have a torquer size cam on a 111 and mine drives great. Just a little cranky at cold start but I can deal with it for the gains...
To the OP.... I hope you get it all straightened out... You have had a time with this car. When they are right these car are great fun but they can also be VERY frustrating
Hey Longshot had to rent a U-haul and do that the one and only time my car left me walking. At the time I didn't know anybody with a code reader so did it to find out the stinking MAF was bad. The weird part was I suspected the maf and and unhooked it to run open loop and it still wouldn't go 5 feet before knocking off.....
