cam for 4.8. tr220 or tsp212/218?
Old 04-15-2010, 06:41 PM
b_evans06's Avatar
Default cam for 4.8. tr220 or tsp212/218?
Looking for a cam kit for my 84 cutlass. Motor is a 4.8 and I have talked to both companies and this is what they each recommended for my setup. My question is will I gain anything by choosing one over the other? Or will the difference be minimal? Setup is a carbed 4.8, th350, 3600 stall, 3.73's, and ~3200lbs. And the choices specs are: tr220/220 .551/.551 and the tsp212/218 .558/.563. Any other recommendations are welcome. Thanks.
Old 04-15-2010, 07:17 PM
Paint_It_Black's Avatar
What size intake valve is in the 4.8 and what intake is on it?
Old 04-15-2010, 07:22 PM
b_evans06's Avatar
stock 862 casting heads with a gmpp carbed intake.
Old 04-15-2010, 07:40 PM
ok, so 1.89"/1.55" valves and a vic jr?
Old 04-15-2010, 07:48 PM
b_evans06's Avatar
yea i think thats right.
Old 04-15-2010, 08:08 PM
What LSA are those cams on? And what are you using the car for?
Old 04-15-2010, 08:13 PM
13 Second Truck Club
726.0chevelle's Avatar
A lot of truck guys are having a lot of sucess with the 220 cam so it gets my vote
Old 04-15-2010, 08:16 PM
b_evans06's Avatar
Thunder racing said 109 lsa. It will be driven regularly during warm weather. Not much highway driving since I live and work in town. Not real worried about track times just want something fun to drive with decent power. Upon finishing college I hope to step up to a 6.0L but that is a year away.
Old 04-15-2010, 08:20 PM
if you want the cammed car sound get the 220 you prob want hear the 212 218 much
Old 04-15-2010, 08:27 PM
I ran the engine through some dyno simulation software and drag software, as well as checking a few things out in pipemax.. I'm going to PM you my result but it is different than the 2 cams you were recommended, and will outperform both for your setup. I am assuming long tubes and mufflers.
Old 04-15-2010, 08:30 PM
b_evans06's Avatar
Yea 1 3/4lts and xpipe with duals.
Old 04-15-2010, 08:44 PM
PM sent.
That cam should go low-flat 12 in that car with that cam, stock 5.3 heads, shifts at 6700-6800.
Old 04-15-2010, 10:01 PM
LTX355's Avatar
3600 sounds like a bit much for a 212/218 I run this cam in my 5.3 ordered with a 114lsa on xe lobes. with your stall if ur set on one of these two cams the 220 is getting my vote.
Quick Reply: cam for 4.8. tr220 or tsp212/218?
