Rocker Arm Bolts or Studs
Old Apr 16, 2010 | 01:55 PM
phdraperinc's Avatar
Default Rocker Arm Bolts or Studs
Can't decide which to go with. 6 of them were rounded off when i took them off so i had to use a bolt extractor kit.
Currently my setup is:
T1 cam
7.4 push rods
patriot dual springs
stock 241 heads
and i'm waiting for my comp cams trunnion upgrade kit in the mail.
is it worth going with arp studs and making it bullet proof?
don't i need guide plates if i go with studs and won't that also change my push rod length?
is there anything else i'm missing?
if the stock bolts are good does anyone have a part number?
Old Apr 16, 2010 | 02:41 PM
Duffster's Avatar
Were you using an 8mm socket for the removal?
Old Apr 16, 2010 | 03:33 PM
vettenuts's Avatar
Bolts are fine and if properly installed shouldn't present a problem. Proper tools are required to prevent overtightening and you should use a six point socket, not a 12 point. Also, good quality in this case is important so buy a really good six point socket and set it aside for the rocker bolts.
Old Apr 16, 2010 | 04:52 PM
yes i was using a 6 point 8mm socket but a few were rounded before i even started so i'm assuming the guy before put them on with an airwrench or something smart like that. the others just rounded as i was taking them off cause they were on so tight.
any advice on whether i should use studs or order new rocker bolts... if stock rocker bolts then a part number. i've called a few dealers for the part number and they won't give it to me because they aren't allowed to and i wanted to order them online and save some money.
Old Apr 16, 2010 | 06:32 PM
02*C5's Avatar
hahaha great quote.
Old Apr 16, 2010 | 08:22 PM
vettenuts's Avatar
I looked it up and came up with part # 12560961 per my 2001 parts manual. Here's a link to SDPC's part. Rocker Bolt
GM Parts House is slightly less though.
Old Apr 16, 2010 | 09:53 PM
thanks vettenuts!
i still have time before my trunnion upgrade gets in so any input on the arp struts??
Old Apr 17, 2010 | 06:35 AM
vettenuts's Avatar
You need a straight thread stud. Not sure what part you are looking at but most rocker studs are designed for stud mounted rockers (which the stockers are not) and they flare thicker at the bottom where they contact the head (look at the photo on page 46 of their new catalog and you will see the flare and hex head for tightening the stud). A stud like the one in their catalog will not work. Do you have a part number if it is a new part?
Old Apr 17, 2010 | 01:08 PM
that makes sense. i know most aftermarket rockers use the studs so i wasn't sure if they would work for my stockers as well and appparently they don't. i'll just stick with the stock bolts and call it a day. thanks again vettenuts.
Old Apr 17, 2010 | 01:26 PM
SApache40's Avatar
My comp cams trunnion upgrade kit came with new bolts. Might want to wait on buying new bolts until you get your kit.
Old Apr 17, 2010 | 02:14 PM
vettenuts's Avatar
Didn't know that, this is good information. It will be interesting to see if he gets them as well.
Old Apr 17, 2010 | 02:43 PM
perfect timing... i was just about to press submit to order those bolts when i saw this.
Old Apr 17, 2010 | 02:59 PM
SweetS10V8's Avatar
Mine too, I just got them back from being pressed in. Bolts are included!
Old Apr 17, 2010 | 06:57 PM
i ordered mine from summit. did anyone else or did you do the swap where you send yours in and get ones with the trunnion upgrade back?
Old Apr 17, 2010 | 07:29 PM
SweetS10V8's Avatar
I had mine pressed in by Spectacle Solutions. See Below.
https://ls1tech.com/forums/sponsor-s...m-upgrade.html
Old Apr 18, 2010 | 05:19 PM
thanks sweets10v8! i'll give them a call monday and get it ordered. about how long from order to delivery? just curious cause it was backordered at summit til the 26th of this month so i'm sure this will get me running a couple of weeks earlier.
