lq4 as ls1
Old Apr 17, 2010 | 11:53 AM
T-56SLPSS's Avatar
Default lq4 as ls1
lq4 tear down rebuild for 2000 camaro. will be posting issues i have as they arrise. the ls1 motor is blown will be using ls6 intake along with front drive off ls1.
Old Apr 17, 2010 | 12:01 PM
T-56SLPSS's Avatar
i started the tear down on the lq4 yesterday. (this is my 1st ls build). noticed the back side of the crank is not as deep as the ls1 crank also there is no freeze plug. dont think it will be much of an issue. the lq block looks like it has a spot where ur suppose to drill the alt bracket hole. is this right? having trouble getting the crank pully off. special tool?
Old Apr 17, 2010 | 12:27 PM
Slow5.0.'s Avatar
Yes you'll need a crank pulley puller. You can usualy rent them from autozone.
Old Apr 17, 2010 | 02:45 PM
masterz28's Avatar
^Yep, Everything on the Ls1 can be switched over easily, just the alt mount and thats about it.
Old Apr 17, 2010 | 08:56 PM
johnster's Avatar
just leave that one bolt out of the alt it will be fine
