Need Engine Help!!!
Old Jan 6, 2004 | 10:56 PM
99HUGGSS's Avatar
Question Need Engine Help!!!
I am about to pull out my motor and go through it due to several main reasons.
1. Only put 330 hp on the ground(seems weak for what I have done to the car)
2. Pretty bad cold start knock.
3. Oil consumption (between 3-4 quarts between changes every 3000 miles)
I have been told that my lack of power is probably due to compression loss. I have been told by numerous people that I should be putting down 360-380. Does anyone have any input, am I headed in the right direction or do I need to try something else?? All help is much appreciated.
Old Jan 7, 2004 | 08:15 AM
Country Boy's Avatar
Senior Member
Have you done a compression check?
Old Jan 7, 2004 | 09:55 AM
99HUGGSS's Avatar
We tested it on a couple of cylinders and it was 155 on one and 160 on another. We tested it with the throttle open. I am taking it in today for a leakdown test.
