How do you i check push rods?
I know that I can pull my valve cover off, unscrew the rockers, and then just pull the push rods out, but how do i tighten everything back.
Stock GM lifters should be tightened to 22ft-lbs, but depending on the position of the cam, some rockers will be tightened more and some will be tightened less since they will be under different amounts of pressure.
GM recommends that the #1 piston should be top dead center, tighten xxx rockers, rotate crank 360, tighten xxx rockers. But how the hell do i get piston #1 TDC? I don't want to take all my accessories off, and timing chain cover, just to see the aligment dots.
Get intake pushrod to move all the way down = valve closed
This means exhaust rod is all the way up = valve opened
Tighten when valve is opened/rod all the way up.
Isn't this backwards. Sorry
It isn't intake-opening/exhaust-opening. It's intake closing/exhaust opening. When the intake pushrod begins to go down (the intake valve is closing), the exhaust lifter is on its base circle, and when the exhaust pushrod begins to move upwards (exhaust valve is opening), the intake intake lifter is on its base circle.
Edit: By using this method (lifter on base circle), one can also accurately measure for proper pushrod length/lifter preload (with an adj pushrod of course
). Last edited by squirts11; Apr 20, 2010 at 04:38 PM.
