Oil in coolant. Ideas?
Old Apr 20, 2010 | 08:49 PM
johnlv6's Avatar
Default Oil in coolant. Ideas?
I've searched around and I'm just throwing in the towel here...I've got a '99 LS1 with 96k. This evening I discovered a small amount of what appeared to be engine oil on the coolant dipstick. There is, however, no coolant in the engine oil (as I would expect if it were a head gasket leak).
If there is indeed engine oil in the coolant, but no coolant in the engine oil, what is leaking? I'm going to have the coolant flushed and the engine pressure tested tomorrow. I'm hoping that this is just a result of the coolant needing to be changed BADLY.
Old Apr 20, 2010 | 08:58 PM
Zaxz28's Avatar
As far as I know it can go either way or both ways depending on where the leak is....Do you have a power steering cooler on the car...
Old Apr 20, 2010 | 09:12 PM
johnlv6's Avatar
Ah...bingo. I'm pretty sure that '99's have a power steering cooler. The power steering fluid has a slow leak. I bet that's where it came from...not the engine. I'll address that first.
Old Apr 20, 2010 | 09:17 PM
Zaxz28's Avatar
Give it a shot and let us know....
Old Apr 20, 2010 | 09:19 PM
johnlv6's Avatar
Yup. I feel stupid for not thinking of that on my own, but that is actually a far more likely cause (in my case). The engine runs GREAT...I find it hard to believe that it would be the culprit.
Old Apr 20, 2010 | 09:33 PM
Zaxz28's Avatar
It's human nature to think the worst, which is why it's nice to have an objective person lookin in from the outside.
Old Apr 20, 2010 | 10:43 PM
trans_am7935's Avatar
you said 99 LS1's have a power steering cooler, do you know where it is?
Old Apr 20, 2010 | 11:18 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Its right behind your radiator. The metal section in the middle of your radiator hose.
Old Apr 21, 2010 | 06:48 AM
johnlv6's Avatar
Thanks for the info. I'll post up after the dealer takes a peek at it.
