Forged LS1 347 Build..
http://cgi.ebay.com/ebaymotors/NEW-G...Q5fAccessories
Good luck
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
I say sell the darts and get a set of TFS or afr's...even as cast TFS are great bang for the buck under 2k...
also why the -8cc pistons over a -2 or even -4...
what final cc chamber or cr do you plan on obtaining...
https://ls1tech.com/forums/generatio...in-lifter.html
https://ls1tech.com/forums/new-ls1-o...r-failure.html
If you'd like i can keep finding more for you just on this site alone.
Thanks
sorry op
Thanks
sorry op
Of course I have vested interest in this, and I could easily jump onto your side and sell much more expensive lifters and make alot more money. I would rather be honest about the lifters and sell what an application calls for, and in many many cases, it's the LS7 lifters that are the best bang for the buck and that will be completely safe and reliable, even if I make less money on them. Selling the parts doesn't ruin my credibility, that's a ridiculous accusation.
The Cadillac lifters are not good for high spring pressures and aggressive cams and the possibility of a failure increases when used in those applications. That doesn't transfer over to the LS7 lifter as it is a completely different product
In common applications including those of "large" cams the LS7 lifters ARE the best bang for the buck and are completely reliable.
Thanks
sorry op
Im sorry but I have to agree with Scoggin Dickey. I run LS7 lifters in my 347. My cam is has XFI lobes on the intake and XER on the exhaust. Been running this setup for 2 year and 20k miles without an issue. You can't buy LS1/LS6 lifters anymore, the LS7 lifter is the replacement lifter. The LS7 lifter failures that were posted above can happen to any lifter of any company. Does anyone remember the old Comp R lifters and all the issues they had with them. The LS7 lifter is flat out the most used lifter in the LS based engine so statistically speaking you're gonna have a few failures hear and there. That doesn't mean that LS7 Lifters are no good with aggressive cams.
I am sure the op doesn't want his thread turning into a lifter back and forth if any one else would like please start a different thread out of respect to the op.
RPM is a stand up shop and you get what they promise... Let me know and I may be able to follow you and give you a ride back.
. again op my apologies.
Thanx for the advice man and I appreciate you not just throwing your opinion out there without any back up like alot of ppl on this site do...also thanx for getting this thread back to the topic!
I hit 413hp at the wheels with a cracked piston running TSP PRC Stage 2.5 5.3L heads, a Comp Cam 111LSA 228/224 cam .578/.586 cam with an LS6 intake, underdrive pulley, long tube headers, no cats, upgraded oil pump, and slightly ported stock throttle body. Doing this with a manual 6 speed and a quasi crappy launch at the local track netted me 115mph at 12.6 ish seconds.
Another fellow with good AFR's, a lumpy cam in his 98 camaro and an automatic trans with a high stall was running 11.4secs at 119mph. Kicked my *** out of the water with better flowing heads and the ability to launch like a bat outta hell. His mph and a slushbox suggests he was also making more power with his combo.
Good luck
