Sleeper Cam
Old Jan 7, 2004 | 10:12 PM
LS1_Crazy's Avatar
Default Sleeper Cam
I am looking for a good stock idle cam that produces pretty good hp gains...i have looked into the Thunder Racing "old man" cam (tr115)...does anybody have any negative or positive info on this cam...or is there another cam that would be better with a very stock sounding idle...any help would be appreaciated
Old Jan 7, 2004 | 10:20 PM
jrp's Avatar
jrp
SN95 Director
check out the mti stealth cams. coloniel has the S1 i believe and is making great power with it.
Old Jan 7, 2004 | 10:23 PM
LS1_Crazy's Avatar
how is the idle on the mti stealth cams...if you know...how much hp are you thinking that the S1 can produce on stock heads
Old Jan 7, 2004 | 10:27 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Not sure about peak hp figures about the MTI stealth cams, but if i were into getting a silent setup with stock idle, those would be the cams i'd be lookin' into.
Old Jan 7, 2004 | 11:07 PM
Bowtieman4life's Avatar
My cam idles at 750 and makes good power. See below. PM if you are interseted in a similar one.
Old Jan 7, 2004 | 11:27 PM
Taspeed's Avatar
Man..the ultimate stealth cam is the GT2-3. And in an M6 car it makes 400+ Auto are making 390+ with heads
Old Jan 7, 2004 | 11:30 PM
goober35's Avatar
Yes sir they sure do. Made 390 look on the dyno. It is a kick *** cam. I am changing the set up hear soon i will be selling it for $225 so if you want to wait i will send it to you.
Old Jan 8, 2004 | 12:08 AM
BRIAN98Z28's Avatar
what are the specs on the gt2-3 cam?
Old Jan 8, 2004 | 01:43 AM
LS171Malibu's Avatar
I've got a good Lunati cam... 221/221 .510/.510 on a 116 that made good power in the original owners C-5 that I'll sell for a 100. I just pulled it out of my engine and it's a steal at that price.
Old Jan 8, 2004 | 06:16 AM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
Look at this post by Patrick G on the OMC from TR. It made the same power as his TR230...
https://ls1tech.com/forums/generation-iii-internal-engine/11-found-ultimate-old-man-cam.html
Old Jan 8, 2004 | 09:36 AM
LS1_Crazy's Avatar
how stealthy is the idle on a gt2-3 cam...sounds like a pretty bad *** cam if you can see 400 hp...is that with stock ls1 heads?
Old Jan 8, 2004 | 09:40 AM
Taspeed's Avatar
The idle on the GT2-3 is stock. If someone doesn't tell you they have a cam...you won't know it. And as far as the heads go I think they were with stock heads. With ported heads they are getting over 400
Old Jan 8, 2004 | 02:04 PM
LPE SS's Avatar
207/220 .573/.580 @ 118.5
Verrrrrrrrrrry stealthy
Old Jan 8, 2004 | 02:30 PM
goober35's Avatar
I wish i could find a sound clip of the car but it would not matter all you have to do is find any F-body that is stock with header and that is what it sounds like.
Old Jan 8, 2004 | 07:03 PM
Colonel's Avatar
For the record, I run the Stealth Series II cam or "SS2" (224/220 .581/.581 116 LSA.) The S1 (Sanders 1) cam was my 9 second NA cam. It's decidedly NOT stealthy!
11.20 at 121 MPH and a STOCK idle at 650 RPM while pushing 3525 lbs with 3.23 gears. I couldn't be more pleased with this cam. This was with LS6 heads (11.1:1 CR) which add about 10-12 RWHP, IMO. It dynoed 423 RWHP through an A4 tranny spinning 17x11" wheels and 315/35/17" Nittos. Your results may vary. Some people have had a less than stealthy idle with this cam. I dunno. All I can tell you is what mine does.
Old Jan 8, 2004 | 09:01 PM
Trojan T/A's Avatar
If you are going for a stealth setup, I'd go the LS6 cam route. If you go stealth, why spend a couple hundred extra for a little extra power. The LS6 cam has made 390 on stock LS6 heads and over 400 on ported LS1 heads. This cam, with springs costs less than $300. Compared to another "stealth" cam that is 400 for the cam, and another 300 for springs and retainers = $700. With gears or a high stall torque converter, you probably wont see a difference between the cams as you will always be up in the powerband. If you want more power down low, then a stealthy vendor cam would be more appropriate. Just remember that the exhaust system will be the major determinant as to how "stealthy" a cam is.
Old Jan 9, 2004 | 12:34 AM
jrp's Avatar
jrp
SN95 Director
the ls6 wont see gains over an ls1 cam until like 5k. with stealth grinds and other similar cams the gains are peak and under the curve. i dont see the point of doing a cam swap for an ls6 cam unless you keep your car relatively stock.
Old Jan 11, 2004 | 11:39 PM
goober35's Avatar
Gt2-3
Old Sep 18, 2004 | 09:15 PM
ddnspider's Avatar
Hey guys i bought the Lingenfelter gt2-3 cam.my car goes in the shop friday.if you want ill take a clip of the car when its done.its supposed to be the best sleeper cam.
Old Sep 18, 2004 | 09:24 PM
goober35's Avatar
There is no need to get a sound clip of your car. All we have to do is go find a stock car and listen. I have had that cam it is the sleeper for all sleepers.
