PRC 2.5 LS6 heads and Cam question
Old Apr 26, 2010 | 09:22 PM
svg210's Avatar
Default PRC 2.5 LS6 heads and Cam question
hey guys, I've emailed TSP and I havent got a response, so maybe I can get an answer here
Will the tsunami cam clear the valves, with those heads, or will I need to fly cutt?
and what is the best suited cam for AFR heads
I want a street setup with occasional track use, But I aim for better handling drive ablity with the added power
Old Apr 26, 2010 | 09:36 PM
509stroker_ace's Avatar
i'm pretty sure thats one of the cams they recommended to me when i was looking at a h/c kit. i've ended up going a different direction in the cam, but i think thats one that they said would clear.
Old Apr 26, 2010 | 09:40 PM
squale iii's Avatar
Your title says PRC heads...then you say AFR in your question... I'm confused. I run AFR's and have a G5X3 cam. Pulls like a raped ape.
Old Apr 26, 2010 | 09:48 PM
svg210's Avatar
Thanks,
Squale: Yeah, well I am looking at the PRC's while still keeping the AFR 205 in sight just in case
Old Apr 27, 2010 | 11:33 AM
fatmat80's Avatar
SVG210 you should call TSP.. waiting on a email back is the same as waiting on your refund check from the Gov. They are realy helpful and could answer all your questions over the phone. Also i would go with the prc 2.5s and one of there torquer cams..just my opinion..
Old Apr 27, 2010 | 11:35 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
The Tsunami clears without any issues with the Stage 2.5 LS6's. Just make sure when you order the heads that you let us know you're planning to run the Tsunami so we can set them up to clear them.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Apr 27, 2010 | 09:52 PM
svg210's Avatar
Awesome Thanks Matt, I am waiting till I have enough to buy the whole supporting mods that go with it, I would be giving you guys a call when I am ready
Old Apr 27, 2010 | 10:35 PM
Detoxx03's Avatar
I sent them a pm with no reply yet
Old Apr 28, 2010 | 09:17 AM
Sounds good!
Not sure who you sent it to (my box is caught up as of right now). Give us a call. As busy as it is right now with tax season and race season both going on, some of the other sales guys might be a bit behind on PM's...but on the phone you get all your answers right away!
__________________
Old Apr 28, 2010 | 10:55 AM
Detoxx03's Avatar
Sounds good!
I sent you a pm too. I'll try to call if I can get free and/or if you can't respond to my pm
Old Apr 28, 2010 | 11:05 AM
Back at ya!
__________________
Old Apr 28, 2010 | 08:47 PM
svg210's Avatar
hey bro are you back in SA yet?
Old Apr 29, 2010 | 01:03 AM
Detoxx03's Avatar
I will be there on the 14th
