If you like intrique, here's a fun one; Spot on PCM tune, worse than stock HP & TQ
Old 01-10-2004, 02:40 PM
Visceral's Avatar
hrm. Cam timing is my #1 thought. Ive also seen a Flowmaster muffler cost a car 55 hoursepower. Im not kidding. We just took the muffler off the back and the next run yielded 55 more HP. The thing felt like it was hauling a trailer. Plugged cats would do either the same or actually worse. Compression ratio isnt that costly.leakdown is fine, but if all the numbers look OK, and when you take the oil cap off its not huffing, that would be alot to lose to bad rings.
As far as the car taking more money than he thought... Thats the mean, not the exception
chris
Old 01-10-2004, 03:02 PM
Scott Turvey's Avatar
chris
What I meant about the additional cost is, if it was the original installers mistake that is causing the problem, it would be incumbent upon him to make it right. However, as he is dead, that would be an option not available to the owner, as I understand it.
Old 01-10-2004, 03:43 PM
DaleMX's Avatar
If the heads he got have a custom valve job that sunk the valves into the heads abit (this happened to me) then he may have too much preload on the lifters holding the valves open. I ended up shimming my stock valve train .050 to get it right. Got YT's now and still had to shim the crap out of it.
Old 02-04-2004, 08:26 PM
99 Black Bird T/A's Avatar
Received 1,444 Likes on 1,002 Posts
What was the final verdict on this one?
Old 02-04-2004, 09:18 PM
SSInnovations's Avatar
Did you ever figure this out???
Old 02-04-2004, 09:38 PM
Me? No clue me in if I missed something please.
Old 02-04-2004, 09:59 PM
Still waiting for the guy to get his car back in...
Old 02-04-2004, 11:38 PM
JZ'sTA's Avatar
Everyone has great suggestions but here is one more.
Check the tune and make sure that it isn't in the "low octane" setings.
This could *** some chit up.
Have fun and keep us up to date.
Old 02-05-2004, 12:50 AM
strokedls1's Avatar
I know the shop that built the engine and they did bad work. We get our parts from the same guy so it is possible that he has the parts, but they are installed incorrectly. I have the same rotating assembly parts in my car and it runs very well. My guess would be stock heads, no valve work, and incorrect tolerances on all bearings as well as incorrect valve train set up. I would tear the engine down and go through everything. That way I could verify all the parts. I'm sure that is not what the customer would like to hear, but that would the direction I would go.
Old 02-05-2004, 01:28 AM
Sawzall and Welder Mod
Whistler's Avatar
Were all those nice aftermarket engine internals balanced correctly?
Old 02-06-2004, 07:30 AM
Thats what I would be betting on as well.
Old 02-06-2004, 09:03 AM
  #32
Formerly 4mulaJoe
LS1x2's Avatar
My vote is for the cam timing and/or valvetrain setup.
