What cam!!!!
Old May 4, 2010 | 04:06 PM
BLWNLT1_T/A's Avatar
Default What cam!!!!
Here's the deal I've picked up some AFR 205 heads, and currently have the ms4 cam in a stalled auto (4000). Well a buddy of just got some afr 205's and also has the ms4... Well now I am looking to get another cam other than the ms4.... Anything out there that will help me get the edge on him? I was looking at the vindicator cam, its has longer duration and smaller lift. But bigger is not always better... In short I'm looking for something better than the ms4 that will work with these heads...
Old May 4, 2010 | 04:24 PM
Paint_It_Black's Avatar
The EPS 236/248 will do better than the MS4.
http://www.engpwrsys.com/index.php?a...d&productId=11
Old May 4, 2010 | 11:24 PM
Squirts11's Avatar
Are your heads milled at all? If not, doing so is a cheap way to bump compression for some additional hp/tq throughout the powerband.
Old May 5, 2010 | 12:03 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
That grind looks 1/4 familiar to me....
Old May 5, 2010 | 04:26 AM
blk99sleekbeak's Avatar
if i could go back to the time when i ordered my cam i would have had something custom ground. Not that i dont like the vrx5, i just think custom ground from predator z or pat g is the way to go
Old May 5, 2010 | 01:26 PM
Or even better, from someone who specs cams for a living.
Old May 5, 2010 | 01:32 PM
nandos_z28's Avatar
Like?
Old May 5, 2010 | 02:46 PM
KevsfastZ's Avatar
Exactly
Tons of proven cam's to choose from.
Kev D
Old May 5, 2010 | 02:48 PM
Mart00SS's Avatar
+1
Old May 6, 2010 | 02:04 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
If you think they are bad, go ahead and make sure Ed Curtis is in that pile too. Its not rocket science, but you cant just throw numbers on paper and pretend they will work well. Understanding valve events will without a doubt make you more apt to being able to ballpark spec a camshaft. But seriously, talk to Geoff at EPS.
Old May 6, 2010 | 02:19 AM
Geoff at Engine Power Systems
or
Bret at Bauer Racing Engines
Those 2 seem to have a grasp on what works in the LS engines.
Old May 6, 2010 | 04:14 PM
what about the Vindicator Cam... The thing is I don't want to wait two months for the cam to be made... That about how long I waited on my lt1 (slow build so no rush) Just looking for something to give me an edge....
Old May 6, 2010 | 11:22 PM
garygnu's Avatar
most custom ground cams can be produced and on your door step in 1 week.
Old May 7, 2010 | 07:27 AM
Seems to me like there are plenty of predator z or pat g cams out there getting the job done. just becaue they dont do it for a living doesn't mean they do not know what they're doing
Old May 7, 2010 | 08:40 PM
It's not terribly hard to pick 2 lobes out of a comp catalog on a standard lsa/advance and "get the job done" in an LS engine. If by get the job done, you mean "good enough but not ideal."
It's the ones who are making 30-40 ft/lbs more torque below 4000 rpm, a similar or better peak, AND carrying longer, those are the cams a "professional" would design.
Look into 2 recent dyno threads. A custom EPS cam in a 454 making a high torque flatline and an amazing power curve. Then there's the little 224 BRE cam making almost 450rwhp on 243 that ONLY have a valvejob, the cam is HUGE on low end torque.. and the cam carries power to 6800! Those 2 cams were designed by professionals. You aren't going to get anything NEAR that with a typical off the shelf grind you see everyone on here debating between.
I'm sorry if that ruffles some feathers and disturbs the group think that goes on here, but it's the truth.
Old May 7, 2010 | 10:01 PM
GatorFan08's Avatar
Can you post a dyno sheet?? Or maybe a timeslip so we can compare it with wht other cam ony cars run
Old Jun 18, 2010 | 11:12 PM
GrannySShifting's Avatar
or
http://www.yellowbullet.com/forum/sh...d.php?t=255351
Old Jun 19, 2010 | 12:41 AM
z28241's Avatar
To the O.P...Are you just shooting from the hip on this?! there are other ways to beat someone who has similar mods..weight shaving, suspension, traction..are you both A4's?..All im saying is there are other avenues to this approach...just something to keep in mind. If u decide to sell ur cam, PM me, i have a friend on this site whose looking..Good Luck!
Old Jul 11, 2010 | 09:30 AM
347fairless's Avatar
Originally Posted by GrannySShifting
Thanks for the link, almost called him!
Old Jul 11, 2010 | 04:24 PM
Nitroused383's Avatar
He's talking about my setup, click my signature link for all the info.
