ICL explained ?
Old May 10, 2010 | 05:58 PM
slow ride 02's Avatar
Default ICL explained ?
Just trying to understand some things. If one cam is on a 114 LSA + 2 (112 ICL)
and another one of the same lift and dur is one a 114 LSA +1 (113 ICL)
Are they really any different?
Old May 10, 2010 | 06:58 PM
KCS's Avatar
KCS
Moderator
One is just advanced less. Intake Centerline really only tells you how the cam is postitioned in relation to when the piston hits Top Dead Center. Advancing a cam makes all of the valve events happen sooner in relation to TDC, and retarding the cam makes everything happen later.
For example, say both of those cams are 224* cams. If the cam with an ICL of 112 opened the intake valve 10* before TDC, the cam with the ICL of 113 would open the valve 9* before TDC.
