harland sharp rockers coming loose
ANybody had any problems with harland sharpe rockers coming loose? I bought a set and i talked to a guy that had the same set but he had problems with them coming loose. Don't know the guy to well so i wanted to see if anyone else had the same problem. Thanks!!
yup! loc-tite and torque them at 22 ft lbs. pistons @ tdc. if still loosening check threads on heads.
Everyone is scared of running things when its the installers fault that the parts fail and everyone gets all freaked out. For example Comp 918's, HS RR.. Etc.. If everyone installs them correctly you will not have issues. There are SERVERAL people running them without any issues and me being one of them.....
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
I bet a lot of people bought them because they were a pretty bright orange.
Harland Sharps for a few years, same set on their fourth set of heads; no problems.
Nothing is perfect, I would use either Harland Sharps or Yellow Terra (or of course Jesel etc.); yet I have only seen the YT UL failures in person.
EDIT: Actually most failures I have seen were installation error, with the extremely rare material failure.
So this must be the other half when you don't know what you are talking about. ![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
Most Harland Sharps don't like high RPMS, but I guess you would know something like this? Apparently not...
![Icon Eek](https://ls1tech.com/forums/images/smilies2/icon_eek.gif)
Still, I am considering the upgrade to the Jesel rockers anyway; just saying in the years and tons of miles we have had on the Harland Sharps not a single problem with them.
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
We were actually thinking about doing a trunion upgrade to some stock rockers, the only thing that has me hesitant is that we are running TFS heads. There is no way I would run anything less than the Jesels to near 8k rpms... ![Icon Eek](https://ls1tech.com/forums/images/smilies2/icon_eek.gif)
Still, I am considering the upgrade to the Jesel rockers anyway; just saying in the years and tons of miles we have had on the Harland Sharps not a single problem with them.![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
I've seen people have no problems at all with Harland Sharps but around this area they haven't had that good of a reputation of lasting and I know they weren't installer faults. Just kinda ticked me off a little when the above guy pretty much told me they were installed wrong, or I just took him the wrong way.
But yeah, Jesel is definitely in my future build as well
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
I plan on doing a new stroker build pretty soon and it will be 421CI or bigger. Just trying to get away from having to use nitrous to run in the single digits. It won't be a "budget" build like the one I'm currently running.
But yeah, Jesel is definitely in my future build as well![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
