How to remove broken valve cover bolt from head?
I'm parting the motor out and I'm trying to decide if I should take a $100 hit on the price of the heads, or repair it before selling it.
Edit: This is a a bitch to try and ground with the work clamp too. It was pretty shady but I made it work with some southern engineering.
Since it's in the cylinder head, cover everything up so none of the metal gets into the oil. I use tape and paper towels, and even a sho vac while I'm drilling.
Anyway see if you can use some needle nose pliers. The bolt is really small to use an easy out so that probably wont work. Last option is machine shop and they can weld a bolt on there and get her out.
I was trying to judge how tight it was by the shape of that rubber seal under the bolt head. I was going real slow with a ratchet wrench and all of a sudden SNAP
