Which Oil Pump?
Old May 12, 2010 | 11:08 PM
SHovV's Avatar
Default Which Oil Pump?
I'm going to order a new oil pump soon and I'm wondering which one I should get. Scoggin-Dickeys ported/bluprinted/coated Melling pump, ot Texas Speeds ported/shimmed LS6 oil pump? Which one do you guys have, and what's you oil psi cold/hot?
Thanks
Old May 12, 2010 | 11:09 PM
SHovV's Avatar
Texas Speeds oil pump or Scoggin-Dickys oil pump
Old May 12, 2010 | 11:50 PM
Pro_built7's Avatar
MELLING 10296 !
Just put mine in last weekend with my cam install. Runs about 70psi cold and will settle at about 50-55 when fully warm.
You sound exactly in the same position I was about 2 months ago....
I ended up going with the melling because of their history. I'm sure Texas speed and scoggin make GREAT stuff (And I know they do because I run their parts). But when it comes down to oil pumps specifically melling knows best.
If I want a cam/heads/ various performance stuff I'll call TSP.
If I want great parts/ crate engines/ etc.. I'll call scoggin.
(Again- thats not to say TSP/Scoggin don't make great stuff!!!!)
Old May 13, 2010 | 12:09 AM
SHovV's Avatar
Scoggin-Dickys ported, coated & blueprinted pump is a Melling unit. I wonder which Melling pump would benifit me most, #10295 has 10% pressure increase and the 10296 has an 18% pressure increase
Old May 13, 2010 | 01:39 AM
itsslow98's Avatar
I have a melling high volume in mine as well, 66psi cold, 50-55 warm.
Old May 13, 2010 | 01:45 AM
SHovV's Avatar
do you remember which melling pump? the 10295 or the 10296?
Old May 13, 2010 | 07:54 AM
01ssreda4's Avatar
Im running a Melling M295 which is a stock replacement pump. I think people get caught up too much on the high pressure/volume debate.
Old May 13, 2010 | 09:23 AM
Jim_PA's Avatar
I've always thought unless you were running a turbo or a motor with loose tolerances, you should stick with std. volume/pressure, otherwise you're wasting power pumping needlessly.
Old May 13, 2010 | 09:35 AM
Pro_built7's Avatar
10296, like I said before. the 295 is just a stock replacement.
Old May 13, 2010 | 09:37 AM
Pro_built7's Avatar
get the 10296 man seriously. It's also cheaper than TSP/ scoggin as well if I remember correctly
