What kind of oil do you guys run
#61
ok well since this a topic abt oil lol when i start my car the oil presure show abt 40 45
but once it heats up it seems to drop to abt 25 and idk if that normal or nt...
i am using mobil 5-30 can u guys help me out here...
i was thinking its ethier my oil pump or im using the wrong oil?
mods= ms3 cam and longtubes, soon fast 92 and throttle body
#62
yea it goes up but it just brops real low sometimes.. could it be the stupid fram oil filter thats on it causing to lose some presure too? last time i drove it look like 10to20 on the presure it kinda scarred me
#63
yeah, and the manual says to only use 5.5 quarts, yet people on here just put in 6 quarts with no problems..so i guess they are wrong for not following the manual huh? ive also ran castrol GTX 10W-30 on my old 00' fbody with no problems
![GTFO](https://ls1tech.com/forums/images/smilies/gtfoslap.gif)
so i guess people who use other brand oil filters like K & N are wrong because its not an AC delco filter which is what the manual asks huh! LMAO..
your raggin on people for not following the manual, and yet you have aftermarket parts on your car especially since the manual only asks for GM stuff..GTFO!!
#64
yeah, and the manual says to only use 5.5 quarts, yet people on here just put in 6 quarts with no problems..so i guess they are wrong for not following the manual huh? ive also ran castrol GTX 10W-30 on my old 00' fbody with no problems ![GTFO](https://ls1tech.com/forums/images/smilies/gtfoslap.gif)
hell, look at u'r SIG, i guess Everyone should listen to U!
u'r a joke, thanks for the laughs
edit: i didnt know reading my GM manual, made me stupid?!?
#67
Thats varnish and has no impact on lubrication fwiw. It is purely cosmetic. An engine without coolant intrusion into the crankcase WILL NOT form sludge with a oil like mobil 1, unless there is a design flaw, ie poor flow internally, really bad EGR design etc... Mobil 1 is a great oil for a group IV base. There 0w-40 is used in many race platforms throughout the world.
I use Redline 5w-30 and 10w-40. This is a true synthetic ( Polyol ester group V). Proven again and again every sunday at a track near you! I have been using it for 17 years. And yes, I am a regular at bobistheoilguy. I am not a tribologist, but know quite a bit about lubricants in general. This site is great for tech, but all of the oil posts I have seen are laughable.
People recommend using GC at 0-30 to get rid of tick. But wouldn't a thinner oil cause more tick? 0-30 is thinner than 5-30, isn't it?
So I'm in Texas with the scorching summer coming and I have the usual tick noises associated with the 2001 LS1. I'm running Mobile 1 5-30 and would think with warmer weather that an 0-30 would be worse to run, not better. Wouldn't a 10-40 hold up better viscosity-wise in warmer weather and reduce tick (hopefully)?
#68
LOL... my assumptions..lmao..yeah okay, your the one assuming if you use a different weight oil it will be bad...but alot of people have already posted using something different than what the manual suggests..
hey im not using an AC Delco battery, so i assume thats bad right?
#69
I guess I'm a little confused. Please bear with my questions, I'm not trying to be a smartass.
U can only use 5w-30 because the smart guy 01'SSLSX says the manual says so.
#72
#73
LOL... my assumptions..lmao..yeah okay, your the one assuming if you use a different weight oil it will be bad...but alot of people have already posted using something different than what the manual suggests..![GTFO](https://ls1tech.com/forums/images/smilies/gtfoslap.gif)
hey im not using an AC Delco battery, so i assume thats bad right?![GTFO](https://ls1tech.com/forums/images/smilies/gtfoslap.gif)
u'r trying to put words in my mouth.
u'r attempts to slander me are childish
#74
Does u'r ***** hurt?
do u need some vagisil?
u act like my girlfriend on the rag
LOL
#77
your post #5!!.. i said i use a different oil than 5w-30 and you wanna talk smack just cuz its not in the manual with a smart *** comment
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
doesnt hurt me one bit, like i said, i wasnt the one who sent a pm crying..
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
look how many people run different oils other than 5w-30 which GM does suggest, people are running 10w-30, 0w-30, 5w-40, and you dont see them with any problems at all, and most of them get better results than 5w-30.
#78
lol.. thats why he follows the manual..
maybe i should change out my battery for an AC Delco because its what the manual suggests..
i should also take my car to a chevy dealership and get maintenance done because its what the manual suggests..GTFO!! i mean since you did say we should do everything exactly like the manual says.
