which timing Chain?
Old May 16, 2010 | 09:47 PM
Zach3800's Avatar
Default which timing Chain?
trying to fiqure out if there is a double roller timing chain that will fit with out any modfication to the front cover? sorry if its a noob question i did a search and came up with nothing
Old May 16, 2010 | 10:39 PM
peterlawl84's Avatar
I thought SLP's should fit without modification, but I could be wrong.
Also most ppl just upgrade to the LS2 chain, which is much beefier than the LS1.
Old May 16, 2010 | 10:54 PM
supersick99z's Avatar
I got an LS2 when I did my cam swap and for $40 compared to like $150 it's a no brainer!
Old May 16, 2010 | 10:55 PM
blkm6formula's Avatar
double roller is overkill, get a ls2 chain and you will be more than fine.
Old May 17, 2010 | 08:15 AM
04redsilverado's Avatar
Default C5r
get a C5R and be done with it
Old May 17, 2010 | 12:19 PM
sscamaroburn02's Avatar
double roller here and no modifications needed. comes with spacers and everything you need.
Old May 17, 2010 | 04:59 PM
n20kid's Avatar
Manley #73233 clears with ls6 pump..
Old May 17, 2010 | 09:03 PM
soundengineer's Avatar
Manley Double roller ..comes with spacers
also using ported ls6 pump
fits with no modifications to pump or to timing cover
Old May 17, 2010 | 11:52 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Just run a single chain. Chances are you wouldnt be asking any of us in here if you were actually making power that would break a single roller. We would be getting advice from you at that point.
LS2 chain and done. It's easier to install and makes a cam swap that much easier as well.
Old May 18, 2010 | 12:12 AM
its not any harder to install a double chain than it is to install a single chain...
oooo..one extra thing to pull off the crank snout...just need a puller with slightly thinner hooks(I ended up grinding flat the backsides f the hooks on my puller so it could get in there..its a little tight and regular curved jaws dont always fit)
and why not pay the extra to be safe...you dont loose any power from a double chain and its a good piece of mind...
also its not only high power that can snap a single...
lots of miles, or lots of high rpm's can break a single as well
Old May 18, 2010 | 12:21 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
yeah but its like having seatbelts on a couch...
I think a double chain is a pain to deal with cause its just more bulk in the way.
OP:You dont need a double roller. But I'm not here to tell you what you want. Its your car, do what you please. You asked what we thought, so I told you my suggestion and why.
Old May 18, 2010 | 12:26 AM
tell that to my buddy's previous motor....6800rpm and a lot of track time = broken single chain for him
how is it "in the way"?
personaly I dont see any reason to not go with a double chain in your racing motor...if you only plan to daily drive it, and it isnt going to see high rpm's(6500+) and you wont be racing it or going to the track.. then by all means..you only need a single chain..
if you are going to do any of the things mentioned above.. then why not have piece of mind..but the double.
Old May 18, 2010 | 12:31 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Was he running a stock chain?
So the single chain that the C5r ran while racing wasnt enough?
I'm not saying its a bad choice, but most people are looking for bang for their buck. Yeah, if its installed. Great. you can get an LS2 chain for 40$ roughly at the dealership of all places.
Old May 18, 2010 | 12:36 AM
355TurboLT1's Avatar
Double doesn't always equal better. Katech knows this(C5R). If everything is correct on the motor it shouldn't break a chain regardless. Use a TC damper and avoid ASP underdrive dampers, heavy valvetrain and it should last forever wether you are at 900hp or 400.
Soundengineer- Plenty of LS guys have broken double rollers. Do a search. Just because many uneducated people in this country preach bigger is better, does not make it so.. Road racing is much harder on parts(C5R) than any drag racing you will ever do. A timing chain is the last thing you need to worry about. Harmonics break timing chains, not power or high rpms. Think about it, a double is going to be heavier. Whats better at high rpm, light or heavy?...ah ha! Your logic is flawed dude.
Call Katech and tell them how they are idiots for running a single chain in a race motor.
Old May 20, 2010 | 08:52 PM
Zach3800's Avatar
sorry for starting a war but what makes the ls2 chain better? Dealer i work for says its the same chain as the ls1
Old May 20, 2010 | 09:00 PM
I believe the ls2 is just a bulkier chain. FWIW the person who is building my engine has an iron block stroker, running 9.90s on motor, has been for a few years now, has a stock chain, and spins to 7400+ rpm. Stock oil pump and timing chain, never a problem. Double is NOT always better.
Old May 20, 2010 | 09:19 PM
also, we are running a jp performance single chain, true roller, with billet gears, about a 100 dollar set, but a VERY heavy duty set.
Old May 20, 2010 | 09:33 PM
If you do a search, you can find pics of LS1 chains next to the LS2. The LS2 chain is a direct replacement for the LS1 chain, but way thicker. I was surprised when I had them side by side, but I didn't take a pic of it when I was doing my install.
Old May 20, 2010 | 09:39 PM
Justus67's Avatar
LS2 and done, $40. Can't beat it for the money.
Old May 20, 2010 | 11:13 PM
99beaSSt's Avatar
Do you have a link for this this chain? I'd like to see what it looks like.
