cam shaft
Old Feb 26, 2003 | 10:06 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: cam shaft
Sounds like a good combo, those shorty headers are not going to do much for you.
If you mostly race from a roll I'd go with a tight converter like the PI2800. But if you race at the track mostly I'd do a PI3200.
Your original cam choice is fine, you might need to drill out the TB air hole to help the idle once you do the converter and the cam.
Old Feb 26, 2003 | 08:42 PM
viper killer's Avatar
thanks but how cud i drill out the TB air hole ?
Old Feb 27, 2003 | 04:42 AM
ttt
Old Feb 27, 2003 | 05:15 PM
ttt
Old Feb 27, 2003 | 05:23 PM
Cal's Avatar
Cal
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by gold racing:
<strong> thanks but how cud i drill out the TB air hole ? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I'd take the TB off the engine first so you don't risk getting any metal chips instide the engine. Find out what size hole other are using, then put a metal cutting bit on a drill motor or drill press and drill the stock hole out to the new size. Blow out the TB real good with compressed air, then put it back on the engine. Did that answer your question?
Old Feb 27, 2003 | 05:24 PM
Cal's Avatar
Cal
<strong> thanks but how cud i drill out the TB air hole ? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I'd take the TB off the engine first so you don't risk getting any metal chips instide the engine. Find out what size hole others are using, then put a metal cutting bit on a drill motor or drill press and drill the stock hole out to the new size. Blow out the TB real good with compressed air, then put it back on the engine. Did that answer your question?
Old Feb 27, 2003 | 05:25 PM
Cal's Avatar
Cal
<strong> thanks but how cud i drill out the TB air hole ? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I'd take the TB off the engine first so you don't risk getting any metal chips inside the engine. Find out what size hole others are using, then put a metal cutting bit on a drill motor or drill press and drill the stock hole out to the new size. Blow out the TB real good with compressed air, then put it back on the engine. Did that answer your question?
Old Feb 27, 2003 | 05:44 PM
the tb is 80mm shold i drill out the hole.?
and f u have any pics? pleas.
Old Feb 27, 2003 | 09:01 PM
Cal's Avatar
Cal
Since the hole is only active when the butterfly is closed, it won't matter what size TB you have. The blade or butterfly valve of your TB has a small hole in it that lets some air go through to help the engine idle. That's the hole you're going to make slightly larger. Start with computer tuning; you may not need to enlarge the hole. 13/64" or around 0.200" is a typical drill size.
Old Feb 27, 2003 | 09:24 PM
ohh thanks ill try the computer tuning.
but what well hapeen if i do the computer tuning with enlarge the hole???
Old Feb 27, 2003 | 10:53 PM
I just installed THE new cam 216 / 220 .525 / .532 on a 114, hardened pushrods and 918 springs. I also have all bolt ons. Wondering what I should set my rev limiter at I really don't want to over rev my engine. Also where would you expect best shift points to be.
Old Feb 27, 2003 | 11:25 PM
  #32
Cal's Avatar
Cal
<strong> ohh thanks ill try the computer tuning.
but what well hapeen if i do the computer tuning with enlarge the hole??? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I think usually it is best to do both, otherwise the IAC soleniod might get maxed out and cause the PCM to throw a SES. This is a small cam though so I think you could get by with just doing one or the other if you had to.
Old Feb 27, 2003 | 11:29 PM
  #33
Cal's Avatar
Cal
<strong> I just installed THE new cam 216 / 220 .525 / .532 on a 114, hardened pushrods and 918 springs. I also have all bolt ons. Wondering what I should set my rev limiter at I really don't want to over rev my engine. Also where would you expect best shift points to be. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">With that cam I think you would be fine leaving the rev limiter at the stock rpm (6200?) I doubt it will produce additional HP above that, but you could check with the cam manufacture to be sure. I don't know anything about shift points; I'm a 6-speed guy . . . <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Feb 28, 2003 | 12:54 AM
  #34
THANKS <img border="0" alt="[barf]" title="" src="graemlins/gr_barf.gif" />
