coolant leak on trick flow heads!! help!
Old May 30, 2010 | 10:32 AM
Bad98SS's Avatar
Question coolant leak on trick flow heads!! help!
I just installed 225 trick flow heads on my ls1 and i went to put coolant in it and it leaked out of a hole on the side of the heads, does anybody know what that is or if i need to plug it with a pipe plug or a bolt and if so what size. It is on the passenger side of the car. Thanks.
Old May 30, 2010 | 10:39 AM
99FormulaM6's Avatar
you need to take the plug out of your stock heads and put it in there. When I did my head swap, I put my coolant temp sensor there. Either will work.
Old May 30, 2010 | 10:42 AM
Bad98SS's Avatar
where is the coolant temp sensor at?
Old May 30, 2010 | 10:58 AM
jabird's Avatar
On the passenger side you put the plug and on the driver side you put the temperature sensor from your stock heads.
Old May 30, 2010 | 11:59 AM
LS-1Z28's Avatar
Here's a view from the driver's side...
The passenger side will need/have the plug towards the back since the heads from LH to RH are identical.
Old May 30, 2010 | 12:56 PM
and to clarify my post, I put my aftermarket temp sender there. the stock one stays in the driver side head
Old May 30, 2010 | 05:13 PM
Chris05ssTruck's Avatar
Yes...what they said.
Old May 30, 2010 | 05:24 PM
Darkman's Avatar
And when you get both those holes filled make sure you have cross over pipes or plugs on both front and rear of both heads.
Old May 30, 2010 | 05:48 PM
Bad98SS's Avatar
thanks for the help. got it figured out now on to the next problem. https://ls1tech.com/forums/fueling-i...-pressure.html
Old May 31, 2010 | 08:34 AM
Bad98SS's Avatar
thanks for all your help you people are awesome, leaks fixed, fuel pressure fixed, now no spark!these computer cars are something else, thanks again.bad 98ss" dad.
