Copying a cam?
Old Jan 13, 2004 | 12:33 PM
AustinL911's Avatar
Default Copying a cam?
Say I got some spes for a popular cam, say 234/234 .585/.587 112lsa (just making up #'s). Are those the only specs I need to have a copy of this cam ground? or are there other specs too?
Old Jan 13, 2004 | 12:46 PM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
How much advance if any (to get you ICL) ie. 112lsa with 4 degrees of advance ground in the cam gets you an 108ICL. Then you have to know what lobe you want, etc., etc... Its a lot more than duration @ .050 and LSA
If you want a cam, support the vendors. They have spent the time to work out the bugs in the cams and get the proper component selection. It sounds like you don't want to pay a vendor for their intellectual property and basically steal their work. If you want vendors to continue to devlop stuff, they have to make some money. While this stuff is cool and all doing stuff for nothing doesn't pay the bills.
If you don't know enough to know what you need it might be a bit better (and safer) to order a cam. Here is the information elgin cams needs to grind a cam for you.
www.elgincams.com
ONLINE ORDER FORM / (650) 364-2268 FAX
INFORMATION REQUIRED TO GRIND A CUSTOM CAMSHAFT
Please print out this form and submit it with your order !
Your name:_______________________________
Phone #: ________________________________
Year, make, and model of car:
__________________________________________________
Engine type: (circle one) SOHC , DOHC , PUSHROD
Rocker arm type and ratio
(if applicable):______________________________________ ____
What type of lifters are you going to use? (circle one on each line)
MECHANICAL FLAT TAPPET OR ROLLER TAPPET
HYDRAULIC OR MECHANICAL
What is the diameter of the lifter? (ex. .875")___________________________
Engine size:_________________Compression ratio:___________________
Bore:_______________________
Stroke:______________________
Connecting rod length:_______________________________________
(center to center distance)
What has been done to the heads?
Ported? _____________________________________________
Valve sizes: __________________________________________
Springs you intend to use: _______________________________
Flow tested? If yes, what are the flow figures at .050" intervals:
Lift Intake CFM Exhaust CFM
.050 __________ ___________
.100 __________ ___________
.150 __________ ___________
.200 __________ ___________
.250 __________ ___________
.300 __________ ___________
.350 __________ ___________
.400 __________ ___________
.450 __________ ___________
.500 __________ ___________
.550 __________ ___________
.600 __________ ___________
.650 __________ ___________
TEST PRESSURE @ _______" H20
Transmission type: (circle one) STANDARD OR AUTOMATIC
Is idle important to you?_____________________________________
Description of intake system:_________________________________
Description of exhaust system:________________________________
DIAMETER=_____________LENGTH=_____________________
How is the car going to be driven?_____________________________
What type of fuel will you be using?_____________________________
ELGIN RACING CAMS, 53 PERRY ST.,
REDWOOD CITY, CA. 94063
(650) 364-2187
Old Jan 13, 2004 | 12:53 PM
AustinL911's Avatar
are vendors cams generally alot more $ than a custom one?
Old Jan 13, 2004 | 01:05 PM
J-Rod's Avatar
Most vendor cams come as a "kit" with the proper springs, retainers, pushrods, and all the other "stuff"you need to do the cam swap. They make a small but fair profit on the total cost of the package.
Old Jan 13, 2004 | 01:16 PM
AustinL911's Avatar
oh, ok, so It might not be as bad as I thought then. I'll probably go with a vendor then.
Old Jan 13, 2004 | 02:18 PM
Black02SS's Avatar
I would check out FMS right now. They are running a pretty nice sale in the GP section for a cam "kit".
Old Jan 13, 2004 | 02:30 PM
pewter99SS's Avatar
you also don't know the ramp rates that the vendors use, that could be a major issue with stock lifters
Old Jan 13, 2004 | 02:50 PM
taqwache's Avatar
getting a custom cam cost the same as what the vendors usually charge for theres. i have an odd ball combo so after looking in the comp catalog i found the specs i wanted for a custom cam. then i found out that it was cheaper to go though ls1speed, give them the specs i wanted and buy it though them. if i were to go straight to comp i would of spent about $25 more for the same one. you might want to give them a call.
Old Jan 13, 2004 | 03:29 PM
jrp's Avatar
jrp
SN95 Director
definately go with the sponsors. spec'ing a cam isnt as easy as it sounds, and often times people are less then satisfied with there "copy" cam.
Old Jan 13, 2004 | 03:46 PM
Damian's Avatar
LSX Mechanic
Ditto. FMS is producing one HELLUVA camshaft that cannot be duplicated no matter how hard you tried. Great service, awesome driveability, and well.....Look at my dyno #'s....
josh
Old Jan 13, 2004 | 08:31 PM
Billiumss's Avatar
What are your goals Austin?
Old Jan 13, 2004 | 09:29 PM
LASTLS1's Avatar
6 Second Club Moderator
I would have to say call LG. They put in alot of time on the dyno with cams. I also agree that we should support the vendors on the board. Lou gave me info on my cam to install it, trusting me not to give out the info. They put in too much work to give away there setups! Good luck with your build!
Old Jan 14, 2004 | 12:48 AM
pewter99SS's Avatar
yup, I'm about to run a LG cam in my car they are a good choice. Any of the sponsers will work with you to reach your goals.
