c5 z installing comp 236 238 .601 .605 112
the tuner told me tht i needed some headers and catless x pipe and to go with kooks 1 7/8 and 3 in catless pipez and said i would put down easy 400rwhp+ 375rwtq+ wut do u guys think its possible with only full exhaust vararam comp 236 238 .601 .605 112 lsa possible or not?
Reason you are going to have to tune for every single thing you do from now on. Get your FAST get your LT, what injectors are you running. I would do 42's they will support up to 600 rwhp this will make sure your not running more than 80% duty cycle on your injectors. I would also jump to a 90MM tb set up if you haven't already. But your biggest concern right now is getting LT you are leaving a lot on the table that no tune is going to be able to pick up.
keep us informed and good luck.
#33
LSX Mechanic
#36
kinda late on the update but i did the headers set up about 3 months after the cam set up .... this is what i got..
i went with LG motorsports "street series" longtube headers 1 3/4 , with catless x pipe got it retuned the day after the install..
and the car put down 433 RWHP 400 RWTQ
i went from 380 RWHP to 433 RWHP
went from 360 RWTQ to 400 RWTQ
big difference in power my tuner said i was choking the crap out of the cam with out headers thats why the numbers were not tht high when i did the cam swap before the headers..
base line numbers on the stock c5 z before i started modding was 325 rwhp dnt remember the torque numbers
what do you guys think about the end result??
