A troubled 404 Stroker...***UPDATEDD** PLEASE READ LAST POST!
Old Jun 2, 2010 | 10:30 AM
fastest94v6's Avatar
Default A troubled 404 Stroker...***UPDATEDD** PLEASE READ LAST POST!
I go to start my car after a few weeks and this car isn't budging at all....Its clicking like it's the starter...I changed the starter and still the same thing...so I decided to pull out the plugs and turn it manually but still no luck..it's like it is locked or something...THE PLUGS HAD WATER ON THEM!! WTF?? This motor has barely 3000 miles on it! Any suggestions on what it can be lS1tech!??!
Old Jun 2, 2010 | 11:07 AM
Darkman's Avatar
Sounds like a cracked head/block or blown head gasket has allowed the block to fill up with water. What does the oil look like?
Old Jun 2, 2010 | 11:21 AM
The oil is clean..doesn't look like water in there...
Old Jun 2, 2010 | 11:22 AM
JL ws-6's Avatar
Race your car!
head gaskets
Old Jun 2, 2010 | 12:34 PM
King Nothing's Avatar
whoops! pull your heads off and see whats in there. good luck with it!
Old Jun 2, 2010 | 05:18 PM
Guys it's not coolant at all..it's literally Water! And I can't even turn the motor manually!!
Old Jun 2, 2010 | 05:40 PM
pull the heads and see if you locked it up
Old Jun 2, 2010 | 09:41 PM
S10xGN's Avatar
At least pull the plugs and see if it'll turn over...
Old Jun 2, 2010 | 10:02 PM
Bad Notch's Avatar
put it in neutral or jack the back wheels off the ground THEN try and crank the motor over. Your tranny might be locked up.
Old Jun 2, 2010 | 10:32 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You totally didnt make it to the second sentence of his original post.
Lol! The point is that there is water coming out of the cylinders when he pulled the plug. I would lean towards it being something in the motor over the transmission.
Old Jun 2, 2010 | 10:41 PM
S10xGN's Avatar
DOH, I hate when that happens!
Old Jun 3, 2010 | 01:30 AM
i'm leanin towards possible hydro-lock
Old Jun 3, 2010 | 01:48 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
He will find out for sure when he takes the heads off I bet. Sucks.
Old Jun 3, 2010 | 12:13 PM
yes it does . . . course with me i was laughin when #7 rod shot out the side of the block but i have issues lol
Old Jun 3, 2010 | 12:40 PM
cutlass_455's Avatar
Start with the simple, easy and cheap things....pull all the plugs, keep track of where they came from, do you best to inspect the holes....stick something down them so see if they come out wet. Try to move it with a wrench on the crank pulley, but not too hard.
If they cylinders are dry, and your oil is clean, try spraying some fluid film into the cylinders and leave it sit over night with the plugs back in. Try to rotate again tomorrow.
Old Jun 3, 2010 | 03:32 PM
Best advice yet! I'm gonna try this...rings might be rusty from sitting with that mysterious water getting in there!
Old Jun 4, 2010 | 11:36 PM
Any progress??
Old Jun 5, 2010 | 11:53 AM
Any progress??
I sprayed it last night...I'm gonna give it a bit to seep in. I used PB blaster. Fingers crossed
Old Jun 5, 2010 | 01:47 PM
good luck with it!
Old Jun 9, 2010 | 01:20 PM
434strokergt45r's Avatar
Banned Scammer
sounds like head is cracked or maybe a leaky injector cheack for fuel
