Over-rev?
Old Jun 7, 2010 | 08:59 PM
LS-1Z28's Avatar
Originally Posted by LS1T56FTW
Now with those bolts, would I still have to worry about spinning a bearing at 6500ish, or would that only be a precaution for breaking/stretching a rod bolt?
I haven't seen too much on bearings being spun... a good oil pump will help out though.
I'd say with the rod bolts swapped out with the katech you should be good @ 6500 RPM. You definitely won't be breaking any rod bolts at 260,000 psi tensile strength. I have a set that I never used (I ended up just using the rod bolts that came with the eagle rods that are good for 190,000 psi tensile strength). If you're interested send me a PM.
