We copied an aftermarket cam and had nissan install it and fked up our car
Old 06-13-2010, 10:42 PM
  #241
printmanjackson's Avatar
Originally Posted by 1SIKZ31
making a video won't prove anything, As I have access to three coworkers with ls1 camaros. I'm telling you guys it is a running car though.
With the exception of 1 broken lifter, and 3 fucked up cam lobes nothng happened. Actually on the cylinder with the broken lifter an intake valve bent ever so slightly, it still seats 100% on it's seat and passed our compression test with flying colors. I don't see how this car running isn't believable?
Either way though this car is now on the road and driving flawlessly!
I believe you
printmanjackson is offline
Old 06-13-2010, 11:04 PM
  #242
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Originally Posted by crainholio
This thread is headed back toward epic territory. A bent valve that seats and doesn't leak?
Sounds believable...
Lol, yeah, remember how it ran for 100-200 miles just fine on an MSFail4 cam? Bent valve = not 100% running just fine, but that is just my opinion.
This ship has sailed and seems to be headed back to port for a refill on failure.
Be sure and let us know when all the regrind metal makes its way into a vital part or passage and you "don't know wtf happened".
orangeapeel is offline
Old 06-14-2010, 01:16 AM
  #243
Quik Sand's Avatar
Quik Sand is offline
Old 06-14-2010, 01:49 AM
  #244
flintwrench69's Avatar
And how would you know if the intake valve was bent ever so slightly? Did you pull the head & check it that way or could you tell with the valve cover off? Please tell us what you did to find the EVER SO SLIGHTLY bent valve. Either its not bent at all or you have a cylinder with no compression. Sounds like you guys shouldnt even be trusted working on Nissans.
flintwrench69 is offline
Old 06-14-2010, 04:06 AM
  #245
joecar's Avatar
A bent valve can't seat properly... a compression test may compare reasonably good but a leakdown test will fail.
Nothing happened does not equal 1 lifter, 1 valve, 3 lobes...
How did you f.u. the 3 lobes...?
joecar is offline
Old 06-14-2010, 04:31 AM
  #246
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Is this the same person testing it that chose the first set of pushrods and reground cam?
Old 06-14-2010, 10:28 AM
  #247
98TAjwh's Avatar
for 1SIKZ31
Attached Thumbnails We copied an aftermarket cam and had nissan install it and fked up our car-fail_20at_20failing.jpg
98TAjwh is offline
Old 06-14-2010, 03:51 PM
  #248
1SIKZ31's Avatar
Lol wow guys!
The heads were pulled off, and the motor was out of the car, no idea how the bent valve was found/checked, as I wasn't at work.
Of course the oil was changed!!!!
Don't know about the future, but it's running right now!
1SIKZ31 is offline
Old 06-14-2010, 04:38 PM
  #249
Lol wow guys!
while we wait
Old 06-14-2010, 04:56 PM
  #250
KCS
Moderator
KCS's Avatar
Lol wow guys!
I for one am glad to hear it's running again, and I hope it stays that way. It sucks that you guys had to learn the hard way, but that's life.
KCS is offline
Old 06-14-2010, 06:19 PM
  #251
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
10,000+ views and climbing
Z28/2002 is offline
Old 06-14-2010, 06:28 PM
  #252
J LT1 TA's Avatar
J LT1 TA is offline
Old 06-14-2010, 06:50 PM
  #253
Lol wow guys!
So what youre tellin us is the heads were removed & a bent valve was discovered but because it was just bent ever so slightly you decide to just run with it instead of replace it? Super geniuses indeed I wouldnt let you guys check the air in a tricycle.
Old 06-14-2010, 07:29 PM
  #254
NoTractionLS1's Avatar
Funny!
NoTractionLS1 is offline
Old 06-14-2010, 08:25 PM
  #255
Lol wow guys!
It'll be back
Old 06-14-2010, 10:10 PM
  #256
Quik Sand's Avatar
http://www.youtube.com/watch?v=ke5Mr5eCF2U
Old 06-14-2010, 10:14 PM
  #257
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Lol wow guys!
It's pretty easy to replace a valve. If the heads were off that was retarded to not fix it right there. Plus, how do you know it was bent? You can't go off that old saying "Good enough for government work" when it involves precision moving parts.
Of course the pushrods were measured!
You seem to be hiding something. Were not sure, but its pretty easy to find out when you wait a month and start asking about being really down on power. But not for someone you know. Ya, just someone you heard about that works with someone you know. This thread will be remembered for years to come. I promise you. Its already been linked on facebook and a few other forums. Your lack of participation is just going to make it worse.
Get some of your LS1 co-workers in here. I want to see what they really know.
Old 06-14-2010, 10:29 PM
  #258
bigfatls6's Avatar
Looks like the cam material wasn't proper hardness.
bigfatls6 is offline
Old 06-14-2010, 10:31 PM
  #259
Zmg00camaross's Avatar
Orangeapeel cracks me up It does say the RETARD ELIMINATOR under your name for a reason. Tearing this little guy apart. Epic thread of fail here.
Zmg00camaross is offline
Old 06-14-2010, 10:44 PM
  #260
1989GTA's Avatar
"Looks like the cam material wasn't proper hardness."
Especially after it had been reground not once but twice.
1989GTA is offline
Quick Reply: We copied an aftermarket cam and had nissan install it and fked up our car
