Power
Old Jun 7, 2010 | 05:26 PM
PrestonYale's Avatar
Default Power
I have been debating back & forth what to run in my T/A WS.6.
I want it to be powerful but streetable, This is my everyday driver as well. The engine is stock @ the moment.
What I came up with for the Bottom-end
Polish Stock Crank
Block Honed
Lunati ProMod Rods
Mahle Pistons
Top-End
Trick Flow 215 Cylinder Heads
Texas-Speed 228rCamshaft
LS6 Intake Manifold (Maybe FAST 90?)
Stock TB Ported & Polished (FAST 90mm)
LT Headers (No Cats)
I don't know about exhaust, True dual? Single?
How much Power do you believe I would make?
Old Jun 7, 2010 | 09:19 PM
LS-1Z28's Avatar
looks good!
you might want to consider throwing in some rod bolts... (installing the lunati bolts?)
A wild guess I'd say you would be anywhere between 450-500 at the wheels... :dunno:
Old Jun 7, 2010 | 09:42 PM
LS-1Z28's Avatar
- any plans for a bigger oil pump?
- timing set?
also, are you pulling the block out? If so...
- Since you're replacing the pistons and depending on how many miles are on the car I would consider boring it to straighten out the cylinders. Any machine shop can take some measurements to see if you should bore it out or not.
- new cam/crank/rod bearings...
Old Jun 7, 2010 | 10:09 PM
djsanchez2's Avatar
I say you would be closer to the 425-450 range with that set-up.
Exhaust is a personal choice on sound. If you do Duals you can get away with 3", if you do single go for a cutout on the I-pipe or get a 4" catback (Mufflex, etc.) What LT's will you be running?
Aftermarket rods will come with rod bolts, don't worry about that part.
Is it A4 or M6? Stock rear or 12 bolt or 9 inch?
Also you would want to hone the cylinder not bore them unless you want to go with larger pistons or a stroker kit. There is a difference between the two. Unless your cylinder walls are scored, rough or untrue, it should not be needed.
I would deff. do a ported oil pump and LS2 timing set for insurance.
As for heads you might want to look at the AFR 205's. They are comparable and have better flow down low to produce better tq. for a DD. Where you will be in the power band 95% of the time anyways,.
Old Jun 8, 2010 | 12:02 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Pump and chain are not only good insurance, but a worthy upgrade.
Old Jun 8, 2010 | 12:18 AM
kmracer's Avatar
why are you rebuilding the engine?
Old Jun 8, 2010 | 05:07 PM
garygnu's Avatar
the TSP 228r mite make 450 rw,consider a EPS cam.
Old Jun 8, 2010 | 05:17 PM
9secondsflat's Avatar
stay with the tfs 215, you WILL gain more power and more torque accross the curve as compared to the antiquated afr 205's
Old Jun 8, 2010 | 05:53 PM
I was thinking running the Pacesetters for now, then upgrade to ARH LT.
I will look into the AFR 205's tho
Old Jun 8, 2010 | 05:56 PM
I'll definately look into that 4 sure.
Old Jun 8, 2010 | 05:57 PM
Yeah.... I really do like those Cylinder Heads. I'm open 2 any suggestions 4 sure tho
Old Jun 8, 2010 | 05:58 PM
EPS huh? I never heard of that cam. Is that a paticular camshaft or is EPS the manufacturer?
Old Jun 8, 2010 | 06:00 PM
The previous owner ran the hell out of it, I might be good to go. Hell, I figured if i am going to sink good $ into the top end I might as well have a bulletproof bottom end ya know?
Old Jun 8, 2010 | 06:02 PM
- timing set?
Thank you 4 your input I most likely will need to upgrade the oil pump and get the double timing set... I did not really think of that.
