I am going to have to flycut!!! :(
Old Jun 11, 2010 | 01:10 PM
LilJayV10's Avatar
Yes it is a check spring. The heads are from TEA. I bought them off a trusted member here last year. When I used the adjustable pushrod I had the dial indicator on it to make sure I didn't pick up any preload or valve lift in this matter.
Old Jun 11, 2010 | 02:27 PM
printmanjackson's Avatar
it's got to be the way TEA set the valves in the head. I'm sure they did it to increase compression. Can you post a close up shot of the heads showing the valves?
Old Jun 11, 2010 | 02:58 PM
vettenuts's Avatar
Straighten out the dial indicator and then see what happens.
Old Jun 11, 2010 | 05:50 PM
chrs1313's Avatar
If you need flycutting tools I have a set I can rent out...sounds like you are measuring everything correctly...
Old Jun 11, 2010 | 11:16 PM
LilJayV10's Avatar
I am going to do that to help eliminate it. I can't see it changing it .060 but it might.
Chris1313 my valve sizes are 2.02/1.55
Old Jun 12, 2010 | 12:19 AM
LilJayV10's Avatar
How much can you flycut stock pistons? If these readings are accurate I am going to have to cut atleast .060 off. If I can go more than that I will to be able to mill the heads and up my compression. Does anyone know how many thousands equal 1cc? I am wanting to get around 60-62 to get my compression up.
Oh I hate math!
I am only wanting to do this once and do it the right way.
Old Jun 12, 2010 | 08:12 AM
chrs1313's Avatar
yup I have tools that will work for those valves...
Oh I hate math!
as for the 1cc is around .007-.0075" when I cut my heads...so taking off .025 should get you right around where you want to be at 60cc...
I have seen people it as deep as .120 and even spray that setup with a 150 shot...the stock piston is around .240 thick...
I personally cut mine to .110 on both intake and exhaust...
I would recommend at least a .080 cut and bump that compression up...free hp...
Old Jun 12, 2010 | 10:25 AM
malibutwins's Avatar
who makes that degree wheel?
Old Jun 12, 2010 | 03:52 PM
LilJayV10's Avatar
Comp cams. It came with the degree kit. It's only a 180 degree wheel. So after a certain point you have you subtract the number you have from 180. I don't know enough about valve events to figure it out. I think my father in law has one that is 360. Other than that it's a nice piece. I just need to learn how to use it.
Old Jun 12, 2010 | 03:55 PM
LilJayV10's Avatar
I will be spraying 100-150 on it but not that often. If I am reading what you are saying I should be ok. I will have to sit down and do that math. Me and digits.
Old Jun 12, 2010 | 04:01 PM
Nitroused383's Avatar
Did you confirm that the cam is what the cam card states it is? Sounds like it's a bit bigger than 226 on the intake to me. .0065" = 1 cc on a 243 casting.
Old Jun 12, 2010 | 04:57 PM
  #32
LilJayV10's Avatar
That I did not and I don't know how to do it. I should have had EPS do the cam doctor thing on it to verify what it was but damn I thought it would be right. But I also thought I wouldn't have to flycut.
I did go through some numbers with Geoff on the phone about the spec's at certain degrees and they were close. He said after I advanced the cam they would be where they should be.
Old Jun 12, 2010 | 05:05 PM
  #33
LilJayV10's Avatar
So If I mill the heads .025 to get 60cc
BDTC
15 degrees .225 .200
10 degrees .151 .126
5 degrees .098 .073
0 degress .055 .030
ATDC
5 degrees .029 .004
10 degrees .019 +.006
15 degrees .024 +.001
20 degrees .045 .020
If I cut .100 down that would give me the clearance I need? I know I haven't even measured the exhaust yet. Am I doing the math right? I need to call Geoff Monday and see if he has heard of this and how to verify that cam is what it is.
I don't know how much my pistons are sticking up. They don't "look" but a few thousands if that. What is the compression with a 60cc head and a .051 head gasket?
Old Jun 13, 2010 | 01:44 AM
  #34
chrs1313's Avatar
Originally Posted by liljayv10
so if i mill the heads .025 to get 60cc
if i cut .100 down that would give me the clearance i need? I know i haven't even measured the exhaust yet. Am i doing the math right? I need to call geoff monday and see if he has heard of this and how to verify that cam is what it is.
11.2-11.3
Old Jun 13, 2010 | 09:06 AM
  #35
SOMbitch's Avatar
Stock piston is .250 thick and cutting .125 is about as much as recommended to safely cut. Having said that the ringlands are the weakpoint on OEM pistons anyway IMO...
Old Jun 14, 2010 | 05:06 PM
  #36
LilJayV10's Avatar
I spoke with Geoff again at EPS today.
First thing I want to say his customer service is fantastic. He has talked to me probably a half of dozen times about my car and my setup. I can't say enough about him.
After talking today he said the problem, if you want to label it as that, is TEA drops the valves down which reduces PTV clearance. In no way am I blaming anyone. I think this is great example of why you should check things and not just throw it together when you mix/match parts. I don't think this would be a problem if it was a head cam package from a business.
What's the best way to find out how much the pistons are sticking out of the block? Feeler gauges? Dial indicator, if so how do you do it?
Then I can get the heads shaved, I said shaved, then cut the pistons.
Chris I will be sending you a PM about the tools.
Thanks again for everyone's help and input.
Old Jun 15, 2010 | 05:55 PM
  #37
one option is to send the heads to TEA and have them set the valves in deeper then maybe have the heads shaved to get the compression you're looking for.
The only other option is flycut.
If the deck has never been milled I'm sure someone here has the info on how much the piston is out of the block.
Old Jun 15, 2010 | 06:07 PM
  #38
LilJayV10's Avatar
I think the easiest thing to do is flycut. I rented the tools from Chris.
Old Jun 18, 2010 | 12:24 AM
  #39
LilJayV10's Avatar
I dropped the heads off at the machine shop today. I told them I wanted them cut down to 59cc. Afterward I thought if TEA sits the valve that much lower will that effect how much can be milled off the heads.
I guess I will find out.
Old Jun 18, 2010 | 12:35 AM
  #40
Becareful man that much compression with an early ivc will make your dynamic compression ratio real high. If its over 8.8:1 good luck on pump gas. I wouldn't run much over 11:1 with that size cam.
