oil burning????
Old Jun 11, 2010 | 05:47 PM
djkeene16's Avatar
Default oil burning????
my car 00 trans am 168000 miles leaked when i bought it till i got my rear main seal fixed.. all is great till low oil pops up so fill it back up a month goes by and its low oil again is it burning can my car burn this much oil so fast i dont see any white smoke i use royal purple oil???
Old Jun 11, 2010 | 07:56 PM
joecar's Avatar
Might be pulling oil into intake manifold thru PCV plumbing.
Don't let the oil get so low that Low Oil comes on.
Old Jun 11, 2010 | 10:59 PM
garygnu's Avatar
if you are burning oil it would be blueish,check your plugs.get a catch can or a new pcv valve,do a leak down test.your valve seals could be leaking or you rings not sealing.check your coolant color.
