Patriot Stage 3 LS6 heads...opinions?
Im looking for first hand knowledge of Patriot Stage 3 LS6 heads. Im looking at different packages right now and these and the PRC 5.3 stage 2.5 seem to be the heads within my price range (1500 or less new). I found some older threads on here through google with some complaints about quality, but it seemed to be a lot of "twice removed" hearsay type stuff.
Thanks
Thanks
LS1Tech Premium Sponsor
If you have any questions about the PRC line-up or the machinign processes that go they use feel free to call, PM, or email us anytime! We'd be glad to work with you and chose a combo that will fit your needs, budget, and ET/power goals!
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
I have no opinion on the Patriot heads because I have no 1st hand experience with them but I have a question.It sounds like these are for a stock cube LS1? Do you know that stage 3 heads(with 2.08"intake valves)are for 4" and larger bore engines?You should use stage 1 or 2 heads with a stock 3.90"bore.Just pointing that out if you didn't know and if you have a bigger engine then go stage 3.
