which lifters?
Old Jun 19, 2010 | 01:00 PM
mattorx7's Avatar
Default which lifters?
my engine recently broke a lifter which i have read can be common on standard ones i am going to replace the cam with one from vinci high performance called the "butt kicker" but i am undecided on lifters i want the fully encapsulated versions rather than the standard ls1s so i was thinking of
ls7 lifters, new oem lifters or aftermarket of some kind?
my engine spec is: ported standard heads crane 1.8 rockers, double valve springs, titanium retainers, crane 7.25 push rods, stock bottom end, tubular manifolds and ls6 intake
thanks
Old Jun 19, 2010 | 01:02 PM
IWGF's Avatar
Well... LS7 lifters will be fine. But who the **** is vinci high performance.
Old Jun 19, 2010 | 01:24 PM
HotSilverBird's Avatar
http://www.vincihiperformance.com/ thats who the FARK they are! EVER HEAR OF GOOGLE ?????????????
Old Jun 19, 2010 | 01:47 PM
IWGF's Avatar
No. What is this google you speak of?
Old Jun 19, 2010 | 02:02 PM
Darkman's Avatar
Google makes cams?
Old Jun 19, 2010 | 02:34 PM
miami993c297's Avatar
thanks
You have a PM
Christian
Old Jun 19, 2010 | 02:46 PM
IWGF's Avatar
Originally Posted by Darkman
Google makes cams?
Apparently. And they're called "butt kicker" cams.
Old Jun 19, 2010 | 02:59 PM
JPH's Avatar
JPH
I would suggest stock GM oem replacements or a set of LS7s.
Old Jun 20, 2010 | 04:28 PM
Fratsit's Avatar
Old Jun 20, 2010 | 05:05 PM
BADD SS's Avatar
+1
Old Jun 20, 2010 | 05:10 PM
jerflash's Avatar
im used ls7s in my new setup and they are nice a quite running around .080 preload
Old Jun 20, 2010 | 09:17 PM
printmanjackson's Avatar
a cam called "Butt Licker"?
Old Jun 20, 2010 | 09:50 PM
Originally Posted by Fratsit
I was farkin serious!
Old Jun 20, 2010 | 09:59 PM
Gordon0652's Avatar
Morel Link bar!
Old Jun 20, 2010 | 10:21 PM
jerflash's Avatar
link bar setup is bad *** but good luck changing you cam without pulling the heads
Old Jun 21, 2010 | 05:24 AM
Fratsit's Avatar
Easy Brother. I got a good laugh out of your response. With the availability of search engines I cant believe some of the questions that get asked around here.
R/
Frat
By Brett Foote | 2026-06-04 05:00:17
