59cc or 64cc chambers
Old Jun 13, 2010 | 03:15 PM
LS12Fast4U's Avatar
Default 59cc or 64cc chambers
When i purchase my patriot heads which chamber should i run? They say the 64cc heads will bump the compression to 10.5 or the 59cc heads will bump it to 11. If i do the 59cc can i still run 93 octane?
Old Jun 13, 2010 | 04:46 PM
NAVY's Avatar
59cc you will see good power
Old Jun 13, 2010 | 05:06 PM
garygnu's Avatar
what kind of gas can you buy in Idaho?with the 64cc heads you can use a more street friendly cam,the 59cc heads will require a good tune and a more radical cam.
Old Jun 13, 2010 | 06:23 PM
LS12Fast4U's Avatar
Other then racing gas i can get Sinclair 93 octane fuel. But i want to beable to run 91 OR 93.
Old Jun 13, 2010 | 06:33 PM
johnster's Avatar
59cc will be ok with 93 octane with a good tune
Old Jun 13, 2010 | 07:10 PM
JasonSS2000's Avatar
Good tune will be the key. You will be right on the edge w/11:1 CR.
Old Jun 13, 2010 | 07:35 PM
LS12Fast4U's Avatar
What if i go out of town and all i can find is 91?
Old Jun 13, 2010 | 07:40 PM
corvet786c's Avatar
Always keep octane booster with ya, jk dont know.
Old Jun 13, 2010 | 10:40 PM
LS12Fast4U's Avatar
I will probably just go with 64cc heads.
Old Jun 13, 2010 | 11:45 PM
ABQ99TA's Avatar
So 91oct. will not support 11:1?
Old Jun 14, 2010 | 12:54 AM
02*C5's Avatar
64CC chambers not only give u the ability to run 91 or 93 octane but you can also run a greater range of cams with out having to fly cut. I had 59cc chambers and I could only get 91 octane fuel where am at and had to use a bottle of Torco with every tank it gets old after a while.
Old Jun 14, 2010 | 01:03 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I would make a street trim tune for your car then. Or get a water/meth injection setup.
Old Jun 14, 2010 | 03:16 PM
hammertime's Avatar
It's hard to say without knowing how much advance is ground into the CheaTR V3 cam. You would be marginal at 59cc and 91 octane, but it could be done. If you want a better margin for error, 64cc is only giving up a few HP for the piece of mind...
Best bet, call the guys at Thunder Racing and see what they recommend. They should know what works best with their grind.
Old Jun 14, 2010 | 04:20 PM
King Nothing's Avatar
i'm glad i have 67cc heads
Old Jun 14, 2010 | 08:03 PM
black01_WS6's Avatar
I have 59cc heads and an very close, if it was my DD then I would go with the 64cc to be safe, if it is a secondary car then go for more compression.
I think you are better suited for the 64cc as you may have to use 91 octane every now and then.
Old Jun 14, 2010 | 11:20 PM
airforcemanss's Avatar
get a tune by "frost" on here and you can have two set tunes at the flip of a switch
Old Jun 15, 2010 | 02:00 AM
Paint_It_Black's Avatar
Glad I don't have your problems.. the gas station by my house sells 93, 100, and e85.
I went with 58cc chambers and .040 gaskets.
Old Jun 15, 2010 | 02:23 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
what does the 100 unleaded cost ya?
Old Jun 17, 2010 | 12:41 AM
LilJayV10's Avatar
What thickness of head gasket are the suggesting to use?
Old Jun 17, 2010 | 03:13 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You get your PTV stuff all figured out?
