Help.Car turns over won't start. R my PRs too long?
I'm gonna check re-check the cam orientation tonight. If they dots are looking at each other then I'm gonna try less preload on the lifters. I'll loosen the rockers a tad just to see if it'll start. If so then I know that's the problem.
There is another thread on here about comp-r and too much preload (2 turns past 0 lash). He isnt running and is getting a backfire through the intake. He's not sure thats the problem, but it sure sound similar.
https://ls1tech.com/forums/generation-iii-internal-engine/130864-scenario-even-remotely-possible.html
https://ls1tech.com/forums/showthread.php?t=130864
LOL That's me!
LS1Tech Co-Founder
Is the coolant temp sensor in the head hooked up? Is it a 98 block with a 98 temp sensor fitting and you have a 00 male connector?
Stuff like that sensor and the MAF, or not plugging in half of your coil packs will make a car incredibly hard to start.
LS1Tech Sponsor
I didn't read that it's backfiring through the intake...The pushrods are way to long..With milled heads,TR cam and STOCK lifters I run 7.35 pushrods and still have .080 preload.The comp R's recommend the most of .030 preload.I would guess you are hanging the valves open.
Folks let me first say that I appreciate all of you guys hanging in there with me.
Now, I went out tonight and torqued the rocker bolts to 11lbs instead of 22. While doing it I was thinking that it didn't seem to make much difference. I tried to start it and it backfired loud out the back. At least it didn't blow the hose off the manifold this time.
I get home when it's dark and I go to school online at night so I don't have much time to fool with the car unless it's the weekends. So I will have to wait until tomorrow night to check that the timing isn't off a couple of tooths.
Will a .005 mill make that much of a difference to where if the PRs aren't adjusted the valves will hang open?
a few things....
1. a stock length PR will be just fine 7.4"
2. Comp R lifters are only supposed to have .002"-.004" preload..excessive preload will damage the lifters..that being said..you need to switch to an adjustable valvetrain..you need to keep the torque spec to 22ft/lbs..you dont want the rocker bolts to back out..so you will either to shim the rockers up(cheap, non-recomended way) or buy an adjustable rocker(recomemded)
3 the comp R lifter is made for more spring pressure and higher rpm..if you use a standard spring(like a 918) then the excessive preload will most likely cause the valve to be staying open and you not getting any compression..like most have said
#38
Ok first of all you can tell if your valves are hung open by the way the engine sounds when cranking it over. If it has the normal lope sound while cranking then it's okay. If the engine sounds like a .....hmmm.... i guess like your started kicking out and spinning freely without the lope sound then your valves are hung open. If the cam is off a gear yes it more than likely won't start, everything is happening at the wrong time and it the car will backfire. I'd start by getting that thing dead on then retrying.
-Sly
-Sly
