Getting an LQ4 in a trade...need help with heads, etc.
I'm getting a low mileage LQ4 short block with a TSP Torquer V.2 cam, LS1 heads with Patriot dual gold springs, and a Professional Products Typhoon 96mm polished intake and throttle body (and a few other small things...pushrods, ported oil pump, etc) in a trade. This motor is going in my '01 WS6 that's in my sig. I plan on keeping the short block, cam setup, and valve springs for sure. Everything else is up in the air. Would like to maximize the power I can make with the LQ4 shortblock and existing cam, along with the other supporting mods I already have (see sig). Would like to see 425+, but I'm not too concerned with dyno numbers alone.
Heads are the first order of business. I've been looking at PRC 5.3 heads as well as PRC Stage 1 and 2.5 LS6 and Patriot LS6 heads. I know the LQ4 has lower compression due to the dished pistons, so I'd like to bump that up to as high a level as I can on pump gas and not have to flycut. I'd love to throw some AFR or TFS heads on, but it's just not in the budget, unless I get a killer deal on some used ones. Would the PRC Stage 2.5 5.3s work OK with the TV2? I had read about how the 243 heads may work better with the LQ4 due to their design and the increased displacement of the 6.0l, but I'm unsure on that. I know the desired compression will be easier to achieve with the 5.3s, but if I need to get some ported 243s and have them milled, I can. So some suggestions on a head combo would be great.
I read a lot of conflicting info on the PP Typhoon 96mm intake and TB. Most of it indicates that the mani is prone to heat soak and really not worth the money to swap from an LS6. I have both options available (I still have my LS6 intake and Shaner S3 from my old motor), so I just want to use what will work best for me. I read where the Typhoon gives up some low and midrange power to the LS6 but gains a little on the top end...not sure how much this would be affected with the additional cubes of the LQ4. There's also the weight issue. If the LS6/Shaner is going to be just as good, then I'll sell the Typhoon and 96mmTB. If I'm going to see a justified benefit from keeping the 96mm mani/tb, I'll keep it.
Any other suggestions or comments you guys might have would be welcomed. I'm set with everything I need for this swap...the motor is already coming out of an F-body, so most of the necessary items have been done for me. I know I need my accessories, LS1 oil pan, etc, and I think I have all that covered already.
Thanks guys.
Milling the heads is the way you wanna go to up your compression. Just remember you don't need a HUGE cam. A smaller cam will give you a ton of torque and be VERY street friendly on that 6.0...
What are the specs on that Tourquer 2?
Any suggestions on a combo?
the 5.3s milled will offfer the highest scr.
if your gonna use a long duration cam, cutting vr's in the piston is a wise idea.
final scr will depend on gaskets used, which heads, how much milled, and vr volume. but with the 243 or 5.3 it will be closer or beyond 10.5:1
I'm also considering swapping the cam out for something else, maybe a little larger like the MS3 or Tsunami. Thoughts? Just trying to get a good combo for the slightly extra cubes I'll have. It's hard to plan this out since most of the good head/cam info out there is for a stock 346 LS1...I don't even know how much of a difference the extra 18cid will make, or if its something I should plan around.
the ms cams are very similar to trex. so i would assume preparation is the same. i degree any cam, and verify final ptv clearance. you may not have to cut. but doenst hurt to verify. i keep at least .100 clearance. however differnet cam mfg. use different lobes. so similar duration cams may not have similar valve events. even though the durations may be close
