Cam installation tips/suggestions
Old Jul 6, 2010 | 06:51 PM
  #41
JaYZeig's Avatar
thanks for the pics wzup1000 they completed the vision i was trying to make in my head of how this whole scenario happens.
Old Nov 18, 2010 | 09:54 PM
  #42
MrBollWeevil97's Avatar
Originally Posted by wzup1000
^he is correct.
When I did mine, I was nervous about the lifter falling so we did pen magnets and the 5/16 rod method.
However when I looked down the holes, I got nervous about the rods still letting the lifters potentially fall, so luckily I had a spare 5.3 block laying around so I pulled it out and put a set of lifters in it.
I found that the rod will NOT let the lifter fall. No Matter how hard I tried to push the lifters past the rod (via pushrod, in my test block), they would not budge past the rod, and here is why:
There is a ledge on the lifter (like shown)
With the rod slid into the oil holes it rest along the lifters between the ledges (as shown below)
So for those doing a swap, that arent as brave as others doing the "spin the cam, then pray" method. The 5/16 rod method is good insurance, that way you dont have to pull your motor if one does fall.
Wanted to see if I could wake up this topic. I'm in the middle of changing the cam in a 5.3 on a engine stand. I'm able to put the 5/16 rod down the left bank of the engine, but not the right side. Wondering if anyone else has run into this issue. I'm trying not to pull the heads to do this install as I know that's alot of extra work that I don't want to do. Any suggestions here?
Also, the left side shows not sludge build up, but the right side does? Another mystery I'm trying to solve.
Thanks all..
Old Dec 15, 2010 | 06:58 PM
  #43
1FSTLS1's Avatar
Just did my 2nd one. Both times it was very cold outside and I just spun the cam around and swapped them out with in a few minuets.
